Horn problem?
Horn problem?
i have a 2006 superduty...with 50K on it.......the other day i noticed the horn does not work anymore, so i checked the fuse and it was blown, so i replaced fuse, horn still does not work, but when i mash the horn i can here the contacts clicking near the fuse box, so i guess that means everything in the steering wheel near for the horn switch is working since i hear the clicking after i replaced the fuse???? should i chech for power near the horn to see if the horn itself has gone bad? has anyone had this type of issue yet?? thanks for any advice..........
Here you go. . .
This is going on w/ someone as we write. Check out the link . . .
https://www.ford-trucks.com/forums/6...-problems.html
