How to help - Side window glass.
Old Jul 17, 2007 | 11:33 PM
azls1's Avatar
azls1
I need to replace a cracked passenger side window on my 53.
What is involved in replacing a side roll down window? I have the replacement glass and I am not sure how it mounts into the track.
I'd like to have everything I need so that I don't get stuck driving the truck without a window.
Thanks for any help you can give. I did a search, but didn't find a clear answer.
Old Jul 17, 2007 | 11:49 PM
mtflat's Avatar
mtflat
The glass sits in a channel that is attached to the lift arms. The channel holds the special glass-setting 'tape' that grips the glass and the channel.
I just used silicone caulk to hold my glass to the channel. I may have to resort to heat when I decide to remove a window but it works well for now.
Before you pull the old glass out measure how far the glass sticks out past the ends of the channel.
Old Jul 18, 2007 | 08:42 AM
Randy Jack's Avatar
Randy Jack
And get a Shop Manual. It covers glass replacement/installation and is basically indispensible.
Old Jul 18, 2007 | 10:08 AM
Jag Red 54's Avatar
Jag Red 54
I recommend using the special tape and adding some silicone. The glass has to be centered in the channel or the window will not roll up correctly. To get the old glass out, I recommend removing the whole mechanism from the door following the procedure outlined in the manual. Then use a propane torch to heat the old rubber so that the glass can be pulled out. Good luck, Jag
Old Jul 18, 2007 | 11:42 PM
azls1's Avatar
azls1
Thank you everyone.
I never even considered that there would be a shop manual for a truck this old.
I am looking for one now.
Gotanoldtruck
Mar 19, 2014 05:22 PM
AeroZona
Aerostar
Sep 17, 2013 02:25 PM
Bertha1
May 20, 2013 10:48 PM
skimtn
13
May 7, 2012 11:23 PM
Roamer
Feb 19, 2009 12:25 PM
