Sponsored by: Real Truck
2000 7.3 SD Problem
Old Jul 17, 2007 | 12:49 PM
TRICOMEDIC19's Avatar
TRICOMEDIC19
Cool 2000 7.3 SD Problem
Guys I need some advice here.
I have a 2000 with 169k miles. I’ve had it most of its life and take good care of it with oil and filter changes every 3k miles.
Last month (June 07) I pulled a 27’ travel trailer with it and after that, it seemed like it lost power REAL quick. When I would start it, it sounded like it was running on 6 cylinders for 2-3 seconds and then it sounded about half normal. It would make a low growl noise that I’m not used to and lacked power on take off. I cant really tell how its doing at 65-70 mph but seems ok. It misses at idle off and on..
I changed all filters and the oil with rotella last Thursday night. I fired it up and it immediately sounded great.. No more growl and ran like a scalded dog. We latched onto the trailer the next night and boom, right back to the same ol crap 150 miles up the road.
I thought maybe loading it up with the 7000 lb trailer thinned the oil and this would be a short term issue but the next morning, it still ran like crap-o-la.
I don’t get it !!! I’ve read a ton of forums and I sure don’t want to take it to the STEALERSHIP !!! I just changed my own clutch out with a LUK upgrade in a 6 speed 4x4 so I’m ok with the tools.
I've used Sea foam through the tank and filter.. As a matter of fact, I filled the filter housing up with it on the last oil / filter change.
It sounds fine now but I know that once I pull that trailer again, it will go back down hill..
Feel free to email me any suggestions or past experiences to: bryan.faircloth@bradleysmotors.com
Thanks !!!!
Old Jul 18, 2007 | 10:12 AM
TRICOMEDIC19
AS A QUICK NOTE: I was emailed by a guy that suggested that I clean out the IPR valve and screen that is right behind the HPOP... Does this sound like something that would cause the above problem? If so, is it a all day job or a no brainer?
Thanks !!
Old Jul 18, 2007 | 10:22 AM
totin_tools's Avatar
totin_tools
Try to post in the 7.3 forum. The guys over there are very knowledgeable.
2bitsamile
Jul 23, 2014 07:39 AM
cbr600rx7
47
Jan 30, 2013 05:48 PM
fordman19762003
2004 - 2008 F150
May 11, 2011 02:32 AM
TRICOMEDIC19
Jul 18, 2007 05:11 PM
paddler
Mar 30, 2003 12:50 PM
