Coil Spring Perches
Old Jul 16, 2007 | 11:22 PM
fordfan28's Avatar
fordfan28
Coil Spring Perches
On 80 and up 4x4 Dana 44 IFS axles with coil springs, does any know why the passenger side spring perch (cup that the coil spring sits on between spring and radius arm) is about 3/8" taller on the passenger side than the driver's side one? At first I thought I somehow got a truck with the wrong one on one side, but Ford lists two part numbers, one for each side, and I looked at about 10 trucks at the junk yard and they all had the passenger perch taller than the driver's perch.
Just curious as to why and wondering if anyone knows or has a theory????
Most roads are crowned to drain to the sides, so were they pre-loading the passenger side to compensate???
Old Jul 17, 2007 | 12:47 AM
bigbrown84truck's Avatar
bigbrown84truck
i beleive it is required to make both sides ride at the same hight due to the different angles and lengths of the ttb axle halves you gotta remember they don't pivot dead center
brehenkel
17
Mar 11, 2014 12:22 PM
mebe2k
Feb 19, 2011 07:06 PM
"Top Fuel" Bender
Dec 31, 2010 12:51 PM
American Thunder
Oct 6, 2010 05:08 PM
ivanribic
Offroad & 4x4
40
Oct 22, 2005 11:07 AM
