2005 xlt 5.4 engine knock?
Old Jul 16, 2007 | 09:20 PM
shuppy13's Avatar
shuppy13
I bought a 2005 f150 5.4 l a few days ago and has 25000 miles. I noticed it has a slight knock only when engine is warmed up not when it is cold.What could it be and should I worry about it? I dont hear anything when going on throttle. It also has a little engine wobble,thats what I call it anyway. It almost feels like a miss but it is not. You can feel it in the cab and when you drive. Not horrible im just a little concerned. I thought it might be the big engine or the engine mounts? Maybe thats how they all are. Im just used to driving a 78 ford f150. Thanks for any help!!!
Old Jul 17, 2007 | 06:42 AM
Tom's Avatar
Tom
Definitely shouldn't be that bad....but at least it's still under warranty!
Take it in, see if a tech can ride with you so you can point out the problem to them.
Old Jul 17, 2007 | 07:29 AM
FS-150's Avatar
FS-150
Could be the cam phase sensors. Do a search on this forum under "cam phase sensor", cam phaser". There is a TSB (#06-4-7) that pertains to this. Does it sound like a diesel? If you have a bad cam phase sensor(s) it will sound like a diesel "knock", not like a "tick". This knock is usually only heard after the engine has warmed up and the oil has thinned out, and usually is not heard above 1K RPM.
Old Jul 17, 2007 | 03:53 PM
shuppy13's Avatar
shuppy13
It does not sound like a diesel, It is pretty minor. Im more concernd about the wobble that I feel. You can see the engine make like a slight movement almost like it is the engine mounts.When it makes a slight movement that is when you feel it. Is that normal.
Old Jul 17, 2007 | 10:23 PM
Blackstock's Avatar
Blackstock
Former Vendor
The slight knock when cold is fairly common and not a concern. The cam phaser is am easy diag. The "wobble" with no engine light suspect an injector again an easy diag.
alloro
Mar 10, 2017 02:51 AM
BMTodd92
2004 - 2008 F150
Jan 29, 2013 08:19 AM
fordmanforlife246
2004 - 2008 F150
Oct 5, 2011 09:56 AM
2000 roadking
2004 - 2008 F150
Sep 5, 2009 07:28 PM
asteig
2004 - 2008 F150
Aug 25, 2009 08:08 PM
