Turbo Saver
Old Jul 21, 2007 | 01:13 AM
OregonF350's Avatar
OregonF350
Originally Posted by duffman77
I think this is something that many overlook when they shut down thier truck based on exhaust temps. The exhaust temp is largely based on engine load which can change rapidly, but the point of the cool down period is to cool down the turbo. The turbo housing has high mass and will not cool in 30 seconds like the time it would take to cool the sensor (pre-turbo).
That is what I have been seeing with the two guages. I can be pulling my 30 TT down the interstate and pull off to get fuel coasting down the offramp and see pre turbo temps below 400 when I pull into the station. The TTM will keep the truck running though because the post turbo temp is still anywhere from 500 to 650.
Old Jul 21, 2007 | 10:36 PM
kemerick's Avatar
kemerick
So are you saying that it is better to have the thermocouple located after the turbo so you can read its temp versus the engine?
Old Jul 22, 2007 | 12:52 AM
duffman77's Avatar
duffman77
No what I am saying is that if you have the probe located before the turbo, the exhaust tempurate in the gas stream is not the same temperature as the turbo housing until right away. The turbo housing will still be at an elevated temperature until its heat can be transfered into the cooler exhaust stream or into the oil.
Basically a pre-turbo probe tells you whats going on in the engine and a post-turbo probe is giving you an idea of whats going on in the turbo. There are pros & cons of each.
Old Jul 22, 2007 | 06:53 AM
npccpartsman's Avatar
npccpartsman
Here's another school of thought yall might not have considered. Preturbo EGT's are actually a good way to monitor PISTON temps which is where you really have a problem. The pistons will melt long before the turbo impeller melts. Also, with todays oil formulations you don't have coking in the bearings like you did with older formulations which is why there was a need for a cool down/flush of the bearing/bushing. Again, just not needed with todays engineering. I'm not saying you DON"T need a cooldown period after towing long and hard, but for the average trip, IMHO--No. It's just a waste of fuel.
joe blow
Apr 2, 2017 11:22 PM
REPO.
Mar 18, 2017 12:57 PM
Bigdon68
All Things Towing
Jul 18, 2016 01:46 PM
MAD
6.7L Power Stroke Diesel
Jul 6, 2015 02:16 PM
CharlieLed
Jul 22, 2011 12:09 PM
