Sponsored by: Real Truck
2006 cab light install??
Old Jul 16, 2007 | 01:23 PM
rickauf's Avatar
rickauf
Hi all, not sure if i am in the right forum, but i just got a nice 2006 f 250 Amarillo. i would really like some cablights. the ford dealer will not do it at their service, or bodyshop..i suppose i should take this as a sign of leaving it alone, and not having someone drill holes in my roof.
however, has anyone done this?
is there a kit?
i know with the older trucks the plug wire was there factory installed, same with these years?
any input on why not to do it, or how easy it is would be much appreciated!
thanks
rick
Old Jul 16, 2007 | 04:54 PM
WishIhada7.3's Avatar
WishIhada7.3
if the ford dealer wont do it then its best to leave it alone its prob not worth the money and effort.
Old Jul 16, 2007 | 05:14 PM
Beerstalker's Avatar
Beerstalker
Check out the Super Duty forum, there are a few threads in there of guys who have done this without any issues.
Old Jul 16, 2007 | 07:50 PM
Maxium4x4's Avatar
Maxium4x4
Bumped to the SuperDuty section, you should find a good answer here.
Old Jul 16, 2007 | 08:35 PM
carls 250's Avatar
carls 250
done mine a year ago and no problems.
Old Jul 16, 2007 | 09:33 PM
redford's Avatar
redford
FTE Leadership Emeritus
If you don't want to do it, find a Ford dealer that will.
It isnt a big deal.
Old Jul 16, 2007 | 10:24 PM
riggz's Avatar
riggz
I'm planning on doing mine here soon. All you would need is the 5 light heads, some washers/nuts and the wire harness. All for about $75.
Old Jul 17, 2007 | 07:00 AM
Deluxe05's Avatar
Deluxe05
It has been many times. This is probably one of the better write-ups that you will find. http://www.emotoman.com/f250/lights/f250lights.htm
is there a kit?
Yes/No. Some shops are putting together "kits" from the individual parts. You may want to check out a couple of the FTE sponsors, as I know a few have a kit available. It is basically just the OEM parts--the 5 lights and the wiring harness.
The plug is behind the passenger kick panel, if I recall it correctly.
Old Jul 17, 2007 | 11:53 AM
rwilimo's Avatar
rwilimo
It's not a bad job at all. I followed the instructions posted above and had no problems. Use oem parts. Most Ford dealers don't want to do lots of stuff, thats just their nature. If its not quick and easy they loose interest fast.
Old Jul 23, 2007 | 10:15 PM
rickauf's Avatar
rickauf
do i need to take the complete hedliner out? I read a post on another site that said the seats needed to be removed to get acess for the headliner to drop??
mine is a crew cab.. does that make a diff with the headliner size?
also, i did do this along time ago on an 84. there was a "metal shelf" on the roof and the wires need to be fished from the holes, are the new ones the same/
also,,,, the old style just had the one wire coming thru the hole and piggytailed together.. the post seems to show a plug needing to come thru??
Old Jul 23, 2007 | 10:28 PM
riggz's Avatar
riggz
no the only thing you need to remove is the a-post covers, the passenger grab handle, the visors, and the overhead console cover. i just installed mine this week. the wire harness has plugs that plug into each light head. when you drill the center hole, the socket will sink below the roof and you just plug them in to the harness. the only hard part is making sure you have them lined up straight and correctly. the rest is time consuming, but easy.
Old Jul 24, 2007 | 12:46 AM
WilliesSD250's Avatar
WilliesSD250
I did the install on my '06 Supercab. Fairly easy. The most time consuming and scary part was drilling the holes in line. I got my lights from y2kford.com for under a hundred bucks. My local stealer ship wanted $200 for the same OEM parts and another $300 for the install.
Check out my gallery for pics of my install. Also defiently goto emotoman.com and check out his light install writeup. That site and also the spacing dimensions provided by y2kford were a biug help for me.
Fandini
Jul 15, 2013 12:37 PM
Strider27
Jun 3, 2013 08:37 AM
stockhelder
6.7L Power Stroke Diesel
25
Mar 26, 2011 07:31 PM
harley140
2004 - 2008 F150
Dec 30, 2007 10:07 AM
Troy Boy
Sep 11, 2006 06:55 PM
