having problems removing transfer case 1345
Old Jul 16, 2007 | 08:04 AM
sbrimlow's Avatar
sbrimlow
Does anyone have any tricks of the trade to remove a 1345 transfer case.
My transfer case mounts to what looks like a adapter of sorts and then the c6. I unbolted between the transfer case and what looks to be the adapter but can't seem to break her free.
Any thoughts?
Scott
Old Jul 16, 2007 | 02:46 PM
rclarke's Avatar
rclarke
Did you remove all 6 bolts. If so there are a couple of places you can apply a small pry bar to pop it loose.
Old Jul 16, 2007 | 08:14 PM
sbrimlow's Avatar
sbrimlow
The adapter between the c6 and transfer case does this come out with the transfer case or stay behind. I can't seem to get the transfer case loose between the t-case and the "adapter".
Old Jul 17, 2007 | 02:30 PM
rclarke's Avatar
rclarke
I always consider the adapter (extension Housing) part of the transmission and always pull the transfer case off it.
Old Jul 17, 2007 | 10:10 PM
sbrimlow's Avatar
sbrimlow
thanks I got it free!
couldn't seem to free it but there was a threaded hole on the adapter, half way up on the drivers side. Found a bolt that fit. Turned it in a few times and used this and a screw driver to set it free.
thanks
