I know I was just curious if there is any reason I shouldnt use Mecron V and Synrcomesh fluid in it? I was previous running your standard DEX/Merc fill, and decided to change it out today. I used 2 quarts MV and 1 quart syncromesh.
I have been running Royal Purple "Synchromax" for about 6 months. With 189,000 on it, the shifts have smoothed up a bit and the gear noise is down noticeably.
I went ahead and threw it in there. IIRC Mecron V was a synthetic blend. added 2 quarts of Merc 5 and 1 quart of Syncromesh. Had to drain a little cause I overfilled it, but I've noticed that shifter is a lot smoother now, and some of the grinding has quieted down. I think my ranger has 230K on it
