Ford crate engine+stock EFI=????
Old Jan 28, 2002 | 09:40 PM
oldblue18's Avatar
oldblue18
I am already thinking of ways to spend the money I'm gonna earn next summer. See if this sounds feasable to y'all...I want to put a ford crate engine--specificaly jegs part #397-m-6007-A52 into my '89 F-150 4x4. It's the iron head long block 302, advertised 270HP. Can I just transfer my factory EFI stuff onto this motor? (I.E. could it be a direct swap?) Will it run correctly, or will I need to upgrade to larger injectors (and fuel regulator)and a mass-air kit(jegs part #397-m-9000-t50)?
I guess it'll also give me more of an incentive to get around to that S5-42 swap, too
Thanks for your time
Jon
1989 F-150 XL- 4x4, 302, M50D
1995 Bronco Eddie Bauer- 351W, E40D
Old Jan 29, 2002 | 12:37 AM
71mustang's Avatar
71mustang
If you change the crate engine cam for a stock replacement for your truck or comparable you can use your stock fuel injection setup. If you keep the cam from the crate engine it might run ok or you might need to swap to mass air. The stock injectors should be ok.
Old Jan 29, 2002 | 07:19 AM
Caddy 53's Avatar
Caddy 53
It's shame Ford doesn't offer "crate motor" deals like G.M. If they would get act together,might not be as many gm transplant into Ford.
Example: 350 lg blk $1275 New not rem.
Old Jan 29, 2002 | 07:45 AM
shazam's Avatar
shazam
Gee how does one get that 350 to bolt up to a C6 or 429/460 bellhousing ??????
Not to many of them there hybrids here ..
Old Jan 29, 2002 | 09:08 PM
Ford79's Avatar
Ford79
mikeinmilton
Jun 10, 2015 03:10 PM
Bergerson
Aug 25, 2014 07:02 AM
CharlieLed
Feb 24, 2014 08:20 PM
jg09
Oct 3, 2013 02:34 PM
ddwood55
38
Feb 4, 2004 02:40 PM
