F250 to solid axle swap
Old Jul 15, 2007 | 05:36 PM
ajordan193's Avatar
ajordan193
I have a 97 F250HD and would like to have a solid front axle basically making the truck a F350. Reason being i want the front end up higher and would like to make it stronger when holding a plow during the winter months. I would like to hear form those of you that have done this and how you made out and if you ran into any problems along the way. Also in the end how much will it cost to do this?
Old Jul 15, 2007 | 07:21 PM
mrwake's Avatar
mrwake
The axle is probably going to run you atleast 1 grand.. The axle you are looking for is an 85-97 dana 60 ford. It should be basically a bolt up installation.
