Aod, E4od, C6?
Old Jul 15, 2007 | 04:49 PM
Itch71's Avatar
Itch71
Aod, E4od, C6?
Hi guys....noobie Q....I just got a 1996 F-350 5.8 liter 2x4 crew cab....how do I know what automatic tranny it has?
Thanks
Itch
Old Jul 15, 2007 | 04:52 PM
Moore558's Avatar
Moore558
Do you have an overdrive button on the end of the shifter?
Old Jul 15, 2007 | 05:28 PM
Linemo's Avatar
Linemo
if it is an automatic overdrive it should be the E4OD
Old Jul 15, 2007 | 05:57 PM
Itch71's Avatar
Itch71
Moore....I have nothing at the end of the shifter.
Old Jul 15, 2007 | 06:31 PM
Dirigo's Avatar
Dirigo
Automatic OverDrive
Old Jul 15, 2007 | 06:55 PM
Overkill-F1's Avatar
Overkill-F1
What trans code is listed on the tag on the driver's door post?
...Terry
Old Jul 15, 2007 | 07:12 PM
Itch71's Avatar
Itch71
...Terry
That label is so faded I can't tell. Is it safe to assume if I don't have an overdrive button it's a C6?
Old Jul 15, 2007 | 07:13 PM
jroehl's Avatar
jroehl
Originally Posted by Dirigo
Automatic OverDrive
Nope. AOD never went behind the 351, at least not on the 3/4- and 1-tons. The E4OD is also an automatic with overdrive. Look under "TRANS" or "TR" on the door tag and tell us the code.
Jason
Old Jul 15, 2007 | 07:16 PM
jroehl's Avatar
jroehl
Looks like you snuck your post in ahead of mine....anyway, here's some more info:
https://www.ford-trucks.com/article/...ers_Guide.html
Jason
Old Jul 15, 2007 | 07:18 PM
Itch71's Avatar
Itch71
INT TR is 764
TR is G (looks like G faded though)
This is what I got off the driver door
thanks
Itch
Old Jul 15, 2007 | 10:51 PM
archangel's Avatar
archangel
Fleet sales of 50 or more vehicles did offer the option of using the C6 transmission long after it was nolonger offered on the sales floor as a standard option.
So it could still be a C6 if there is no OD cancel ability.
Or someone swaped the shifter and just left the wires hanging.
Old Jul 16, 2007 | 07:25 AM
Itch71's Avatar
Itch71
A C-6 it is!!
Jason
Thanks for the info Jason....The shifting pattern as well as the 17 bolts tell me it's a C-6. They were last used in 96, I guess I got one of the last ones. Seems to be a good HD tranny 3 speed auto....downside is no OD though!!
Thanks for the help everyone....always learning,
Itch
Old Jul 16, 2007 | 09:14 PM
archangel's Avatar
archangel
Itch
And the up side is-----
1: It's not nearly as fragile.
2: It's not willing to fail because of a minor electrical glitch.
3: It's a he11 of a lot cheaper to rebuild than that E4OD P O S!
Also, if you have a C6 with the 3.08:1 rear end, you will have lower top gear rpm's than an E4OD with a 4.63:1 rear end ratio.
You do lose that super low first gear if you gear them alike for the top end rpm's, but I think the added reliability is well worth it.
Or add a Gear Vendor to your C6 (for the cost of 1 or 2 E4OD rebuilds) and have the ability to split all the gears.
Old Jul 16, 2007 | 11:03 PM
pfogle's Avatar
pfogle
I dunno, I know a guy that can rebuild one for $250 parts and labor. You have to take it out and take it to him, but that's not a bad job.
Old Jul 17, 2007 | 07:07 AM
Scndsin's Avatar
Scndsin
Either he's really generous or shouldn't that be $250 plus parts?
