Steering column removal
Old Jul 16, 2007 | 11:34 PM
Fomoko1's Avatar
Fomoko1
Originally Posted by AXracer
The Ford pitman arm was easy to get off, the Toyota that came on the steering box I bought was put on by Godzilla! I broke a bench vise trying to take the nut off with a 36" pipe wrench, and heated it as much as I dared risking the seals. I finally split the nut and pitman arm with a cutoff wheel and cold chisel to get them off!
Dang foreign stuff!
Old Jul 17, 2007 | 10:40 AM
Hot Rods Trucks's Avatar
Hot Rods Trucks
FTE Sponsor
These are all correct ways to remove the wheel but, if all this fails you can pull the column though the floor with box attached its not easy but I have done several different times lots cheaper than ruining the box
