Scanner with reset/clear code ability?
Old Jul 15, 2007 | 09:53 AM
jdemaris's Avatar
jdemaris
I'm trying to diagnose trans problems with my 94 F250 IDI 7.3 turbo-diesel. NOT a Powerstroke.
I've never needed a code scanner before. I've been looking around and it seems the cheap ones in the $30 price range do not allow resetting or clearing of codes. I want something that will tell me error codes, but also allow me to reset the computer to put the trans. back into normal operating mode. Any ideas?
I checked PartsAmerican and they sell the Actron CP9015 that will fit my truck and read codes - but will not clear or reset - costs $30.
They also sell the Actron CP9150 which WILL allow me to clear - but it costs $650 - no way am I going to spend that much.
Any suggestions?
Old Jul 15, 2007 | 10:37 AM
shorthair's Avatar
shorthair
local schucks will loan you a good reader
Old Jul 15, 2007 | 11:22 AM
tjc transport's Avatar
tjc transport
i ain't rite
with an idi diesel, the only codes you are going to get are trans codes if you have an e4od trans.
Old Jul 15, 2007 | 11:57 AM
jdemaris's Avatar
jdemaris
Yes, that's why I want the scanner. I'm trying to diagonose some transmission problems. I also want to be able to reset the computer to put the trans back into the normal mode after an OD flashing event.
Old Jul 15, 2007 | 12:24 PM
tjc transport
i ain't rite
i use the AUTO-X-RAY E-Z SCAN.
it is a very simple to use unit, and is eec-1, obd-1, obdII, and obd generic compatable. cost is around $300
Old Jul 15, 2007 | 02:03 PM
KJLYPW's Avatar
KJLYPW
There is a procedure with the cheap reader to erase the continuous memory codes as well, again, I have the 30 dollar Walmart version, works well.
Old Jul 15, 2007 | 10:23 PM
roamer37's Avatar
roamer37
turn the code reader off while its spiting out codes or unplug the unit from the self test connector... or just disconnect the batterys or the 40pin connector at the processor for 5 mins will do it..
ka9j
Aug 16, 2014 10:53 PM
F-WhiteThunder
General Automotive Discussion
Feb 16, 2013 10:39 AM
tofer76
1997 - 2003 F150
Dec 29, 2011 01:37 AM
PastorPaul
Jul 26, 2010 10:29 PM
