Driveshaft
Old Jul 24, 2007 | 06:30 PM
redrush40's Avatar
redrush40
Originally Posted by MustangGT221
I doubt anyone makes an aluminum shaft...or a CF one either.
Truck guys arn't so worried about their weight as cars are...so the demand is quite low.
Heavy duty shafts on the other hand....you should be able to find easily enough.
But wouldn't ya think that a light aluminum or carbonfiber shaft would reduce wieght, thus increase MPG?
I am actually looking for any tricks for MPG for my 1991 F150 4x4.
I mean by reducing rotation weight? from the powertrain.
TONY Z.
#40
ps... do you have any good sites for a decently priced, good quality rear shaft?
Thanks,
Tony.
Old Jul 24, 2007 | 10:58 PM
MustangGT221's Avatar
MustangGT221
Whatever miniscule additional mileage would quickly be negated by the cost of the driveshaft itself.
Tom Woods custom driveshafts....or anything else you can find in a google search...are the only ways I know of.
Old Jul 25, 2007 | 08:49 PM
lostin90s's Avatar
lostin90s
Hey my shaft was 54 1/2 -55" Sorry the e4od is longer.
Old Jul 26, 2007 | 04:59 PM
MustangGT221
So I put the new shaft in....
got some other odds and ends put back together (fitting on the EGR) and got it running...
...tried to drive it away and under light throttle it will drive ok but when I give it any gas it starts shaking and vibrating through the driveline.
Hope I didn't blow the rear end or the transfer case. If so it better be the transfer case...I just built that rear end a few weeks ago and I have a spare TC.
Old Jul 26, 2007 | 08:04 PM
redrush40's Avatar
redrush40
Yikes!!!
That doesn't sound good at all...
did you check to see if you got the Ujoints in correctly or they might even be bad?
I know when I have had Ujoint in the rear shaft gone bad... it vibrated horribly at 55MPH.
Please keep me informed of the situation.
TONY Z.
#40
Old Jul 27, 2007 | 07:36 AM
MustangGT221
I doubt the u-joints are bad, they are brand new from having the driveshaft replaced, and the shaft was balanced.
I got it up to about 40-50 mph and noticed my speedometer needle was moving around a bit....
...it's the rear end.
Time to open it up....again.
3 weeks ago I pulled the axle and replaced everything except the ring and pinion gears...sandblast/painted...and clearcoated the axle. UGH!
REGGIE_OBE
1997 - 2003 F150
Apr 1, 2010 03:51 PM
Milwaukee1979F150
Sep 2, 2008 07:55 AM
fairlaniac
Apr 5, 2007 04:18 PM
jetjock16
Jul 31, 2005 12:00 PM
truckfreak69
Nov 2, 2002 06:14 AM
