BAD torque converter - WHAT DO I DO?!
Old Jul 16, 2007 | 04:51 AM
btoohey44's Avatar
btoohey44
Doing a flush will cause more problems?
Old Jul 16, 2007 | 02:35 PM
Skandocious's Avatar
Skandocious
I've heard accounts from several people on here who had perfect running transmissions, got a flush done, and then had to rebuild 5k miles later. The flush can break gunk loose from places where it has become "comfortable" and isn't causing problemsand push it into places where it will cause problems with the way that your transmission runs. The flush will clear those extra few quarts that get left in the cooler and lines when you do a TC drain and pan drop, but for a 16 quart transmission, 2-3 quarts is just a drop in the ocean. It isn't worth the risk in my opinion.
Old Jul 16, 2007 | 04:30 PM
btoohey44's Avatar
btoohey44
Ok, I see what your saying.
Reminds me of a 79 Cougar I had when I was in high school. We were doing a tune-up and when we went to change the oil, nothing came out of the drain pan. Turns out after trying to figure what was wrong, we decided just to pull the oil pan off and found a good amount of sludge just sitting on the bottom. We cleaned out the pan, ran some gunk remover through the engine and thought we were good. That is until a week later and every seal had started to leak.
Old Jul 16, 2007 | 11:08 PM
StealthWyvern's Avatar
StealthWyvern
That doesn't sound like my idea of a fun time!
SpectreZ91
Apr 12, 2012 08:10 AM
alfars
22
May 14, 2011 06:52 PM
Ford79
Feb 10, 2011 06:10 PM
miller_feed
22
Dec 8, 2008 09:26 AM
