Sponsored by: Kumho
Banjo bolt???
Old Jul 14, 2007 | 08:20 PM
powerman6.0L's Avatar
powerman6.0L
Unhappy Banjo bolt???
I have a 79 Hp dana 60 front axle. Over the winter I pressure washed it and have since rebuilt it (gears, locker etc). Any way I lost one of the banjo bolts for the brake caliper and cant find one anywhere! is the dealer the only option? I need one asap but none of the local parts houses have one like it. Where can I get one or two of these bolts???????? Thanks in advance
Old Jul 15, 2007 | 06:25 AM
ubereal2's Avatar
ubereal2
Not sure witch bolt you're talking about. Could you pm me with some pictues of where it goes? I have can's of brake parts.
Old Jul 15, 2007 | 08:17 AM
SoArkSI's Avatar
SoArkSI
sounds to me like the one that bolts the outer brake hose to the caliper.
Old Jul 15, 2007 | 11:39 AM
rebocardo's Avatar
rebocardo
You mean this:
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=RAY&MfrPartNumber=H5010 2&PartType=351&PTSet=A
Advance Auto
Raybestos Caliper Housing Bolt
Part Number: H50102
You will need -NEW- copper washers with the little rings on them too.
Old Jul 15, 2007 | 11:59 AM
powerman6.0L
SoArksi you are right! its the one that the hose bolts to the caliper with. It has a hole in the bottom and in the side at the top to let the brake fluid through to the caliper and the hose. Thanks for the help do you know where to get that one??? It is fine thread and longer than a normal chevy one.
Old Jul 15, 2007 | 12:22 PM
ubereal2's Avatar
ubereal2
Let me look through a junk drawer at work tomarrow. If I have one it's your's.
Bob
Old Jul 15, 2007 | 02:25 PM
SoArkSI's Avatar
SoArkSI
If he don't have one. Then I can pull one off my parts caliper. But you would still need new copper washers.
Old Jul 16, 2007 | 06:52 AM
powerman6.0L
Talking
Thanks alot! just let me know. I appreciate your help
KDAVID1
Mar 8, 2015 09:23 PM
Diesel_Brad
Nov 27, 2013 08:10 PM
masseysbronco
Jun 9, 2010 08:15 PM
tubolove
16
Feb 27, 2008 05:23 PM
Scoop531
Jul 8, 2006 06:13 AM
