Pistons types
Old Feb 25, 2002 | 04:46 PM
Crazy Canuck's Avatar
Crazy Canuck
Pistons types
What are the pros and cons of dome, flat and concave pistons? and if you replace your pistons with high performance ones should you change your connecting rods too?
Old Feb 25, 2002 | 06:08 PM
ExplicitHP's Avatar
ExplicitHP
Pistons types
There aren't really pro's or con's. Concave pistons decrease compression to run blowers and turbos. Flat top pistons maintain an OE compression ratio. Domed pistons increase compression for high horsepower naturally aspirated engines. The domed pistons may also require the use of high octane gas to prevent pre-igntion.
You don't neccesarily have to change the rods when you replace the pistons, but if you are building a high horsepower engine you will want to put in stronger forged or powder metal rods.
-Jon
Old Feb 25, 2002 | 06:18 PM
Crazy Canuck
Pistons types
How high a compression ratio can you go on regular pump gas without pre igniting the fuel? and about how much valve lift can a guy get away with, on a 351w, without using pistons that are cut for valve clearance?
Old Feb 25, 2002 | 06:24 PM
canzus's Avatar
canzus
Pistons types
Depends on the design of the combustion chamber, but
9.5:1 to 10:1 is about the max...
Depends on the piston manufacturer, not all pistons
are built to the same specs, but .450" lift is about
max without clearancing...
Steve & the Rockette
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'73 MG B GT 2.6L V6(Ford)
'98 Contour SVT 2.5L V6 (Mods)
'01 ZX2 (No Mods yet)
Old Feb 25, 2002 | 08:09 PM
Lightning2Fast's Avatar
Lightning2Fast
Pistons types
valve clearance also depends on the cams valve events. if your grind allows you can run pretty high lift with no prob.
Old Feb 25, 2002 | 08:38 PM
Crazy Canuck
Pistons types
Valve trains and especially the camshafts are still a mystery to me. What exsctly is a valve event and are there different grinds for different applications? Also how come some cams give you a lopey idle while other high perf cams have a smooth idle?
Old Feb 26, 2002 | 01:03 AM
aksniper's Avatar
aksniper
Pistons types
Well...I don't know much about pistons but I have heard that the dome style ones can lose you about 10+hp. Just a thought.
James
Old Feb 26, 2002 | 10:34 AM
Crazy Canuck
Pistons types
Why would dome pistons cause a loss in horsepower?
Old Feb 26, 2002 | 09:18 PM
notlistedsite
Guest
Posts: n/a
Pistons types
Valve timing events are measurements of valve actions. Like intake valve open, intake valve close, ex valve opens, ex valve closes. These are commonly shortened to IVO, IVC, EVO, EVC. Lobe seperation is the degree of seperation between the max lift of the opposing valves. More seperation is peaky power at a higher RPM, like a 114 degree. Comon is a 108-110 lobe sep. Stay away from dome pistons until you know enough to go there. You can run a flat top, or slight dish with cut heads and get up to 13:1, maybe a little more. Cutting the head makes a more violent squish in the wedge head, and ands decreases the chamber CC's. This makes compression and a better burn. Run a good Venolia or similar piston, have them make them light, and you'll be set. Ballance it, and go!
Old Feb 27, 2002 | 12:09 PM
lt's Avatar
lt
Pistons types
Aaron-71
Jul 12, 2017 08:12 AM
BigBlocker0248
Jan 17, 2016 03:20 PM
Oldyeller75
Mar 15, 2011 10:20 AM
turboman24
Mar 31, 2007 01:36 PM
telesqrt
Oct 8, 2002 07:28 AM
