Turn signal switch effecting breaks
Old Jul 13, 2007 | 05:44 PM
73f100shorty's Avatar
73f100shorty
my turn signal switch is causing my breaklights to alternate. it has a rivet to hold it in place how can i pull it to fix it or better yet replace it thnaks
Old Jul 13, 2007 | 06:52 PM
docholiday72tx's Avatar
docholiday72tx
I don't mean to sound ignorant, but I have a 73 SWB and I don't recall ever seeing a rivet any where on my truck....Could you be a little more specific with your problem?
Doc
Old Jul 16, 2007 | 06:04 PM
73f100shorty
When yout pull the steering wheel off there your turn signal switch. the white C shaped thing. it's held on with a rivet. i don't know if i should drill it out because the contacts on the switch arent connecting right. is there any way to clean them without removing the switch. this problem is causing my breaklights to alternate back and forth so i have to wiggle the lever to make sure that it is in neutral before i step on the brakes
Old Jul 16, 2007 | 06:40 PM
Mil1ion's Avatar
Mil1ion
He's right.,
The Turn signal cancelling cam is help on with a rivet instead of a screw like 78/79 Tilt wheel TS switches.
How is it you think this is causing your BRAKE lights to alternate ?
I say you have grounding problems at the tail-lights that is causing problems.
You didn't even state what symtoms/problems you are experiencing
Old Jul 19, 2007 | 06:00 PM
73f100shorty
after i turn my signal on i have to wiggle the lever to make sure that the switch is in neutral or when i hit the brakes it cancels out the side i turned my signal to before. so when i step on the brake one light works. turn signals are just an interupted brake light right. well after i turn it of it must still be interrupted because then it doesn't want to work so how can i fix this problem?
Old Jul 19, 2007 | 06:13 PM
Mil1ion's Avatar
Mil1ion
Quote: well after i turn it off, it must still be interrupted because then it doesn't want to work so how can i fix this problem?
HUH?
Please explain exactly what you mean or ..what happens.
Old Jul 19, 2007 | 09:34 PM
fellro86's Avatar
fellro86
I've seen it happen before with turn signal switches. What happens is the last light used is the one that doesn't work, so say I had used it for a left turn, the left tail light does not work for the brakes. Replace the switch, and all is good.
Old Jul 19, 2007 | 09:39 PM
73f100shortbed's Avatar
73f100shortbed
Replace switch. I had a similiar problem with left side brake light not working and that fixed it. I had a spare out of another coulmn so it didn't cost me anything.
