Sponsored by: Real Truck
Question re F-250
Old Jul 12, 2007 | 07:15 PM
clayh31's Avatar
clayh31
Question re F-250
Hello everybody. I have a F-250 superduty. It has power everything and remote entry. When i put it into gear the doors do not lock, and the alarm is not triggered when the doors are opened from the inside when the alarm is on. I used to have a F-150 and my friend did some kind of code with the doorlocks and that truck did the same thing. Does anyone know this code?
Old Jul 12, 2007 | 07:57 PM
CounterMaker's Avatar
CounterMaker
your in the wrong forum...you might want to move to the superduty forum further down the page
Old Jul 13, 2007 | 02:37 PM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE, Clayh31
What year is your truck?
Old Jul 13, 2007 | 03:17 PM
clayh31's Avatar
clayh31
My F-250 is a 2000
Old Jul 13, 2007 | 03:42 PM
redford's Avatar
redford
What you are describing is the AUTOLOCK feature. This is from the owner's manual:
To deactivate/reactivate the autolock feature using the keypad
Your vehicle comes with the autolock feature activated. To
deactivate/reactivate this feature:
1. Ensure that the anti-theft system is not armed.
2. Turn the ignition to the 3 (OFF) position.
3. Close all the doors, liftgate and cargo doors.
4. Enter the 5-digit entry code.
5. Press and hold the 7 • 8. While holding the 7 • 8, press and release
the 3 • 4.
6. Release the 7 • 8.
The horn will chirp once when the system has been successfully
deactivated.
The horn will chirp twice (one short and one long chirp) when the
system has been successfully reactivated.
Old Jul 13, 2007 | 03:51 PM
Beerstalker's Avatar
Beerstalker
Autolock was not a feature on the Super Duty until 2002. Also, what kind of alarm is it?
Old Jul 15, 2007 | 08:51 AM
clayh31's Avatar
clayh31
Thank you for the advice, but I don't understand the 5 digit code. Where would I enter that? I also can't find the alarm under in the motor compartment. I don't know where it is located. There is a section in my manual about the keyless entry and the alarm, I just assumed it came with the truck.
Old Jul 16, 2007 | 10:40 AM
Beerstalker
The instructions redford gave you are for the trucks with the exterior keypad that lets you put in a 5 digit code to unlock the doors. You do not have this. And like I said Autolock was not a feature until 2002, so you can't make it work in your 2000.
As far as the alarm goes, are you sure you have one? They are not standard on the trucks, I beleive they are a dealer add on option.
Old Jul 16, 2007 | 11:29 AM
redford's Avatar
redford
Yes, Beerstalker is correct....sorry to mislead you.
Old Jul 16, 2007 | 01:35 PM
wlihntr's Avatar
wlihntr
you dont have the auto lock feature and you dont have a factory alarm. neither where offered in 2000 on SD's
Old Jul 16, 2007 | 02:17 PM
clayh31's Avatar
clayh31
Didn't know that
Thank you guys for the info, I did not know that. The reason I asked is because last thursday some kids broke in through the slider, cleaned out all the change some cash and all the smokes they could find. They went out the drivers door so apparently the alarm does not work!
Old Jul 16, 2007 | 02:32 PM
redford's Avatar
redford
I think sliding rear windows were invented by crooks, to have easy access to trucks.
