Replacement Oil Drain Valve
Old Jul 12, 2007 | 07:04 PM
warrens250's Avatar
warrens250
I recall seeing mention of a replacement oil pan drain valve which lets you turn the flow on and off, and even connect a tube to drain the oil into any container. I can't recall the brand name of the device, and can't find the part on the list of web sites from our sponsors. Will someone please mention the brand and where to order the part from?
Thanks
Warren
Old Jul 12, 2007 | 07:18 PM
ron's power stroke's Avatar
ron's power stroke
http://www.dieselsite.com/index.asp?...PROD&ProdID=33
very cool tool to have
Old Jul 12, 2007 | 07:34 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I have the one with the hose fitting on it. While handy for samples and not having to remove a plug it does make the oil changes a little slower as it is a little restrictive. I still like mine though.
Old Jul 12, 2007 | 07:49 PM
ron's power stroke
it is a little slow.. but doable and a lot cleaner..I crawl under my truck with a pan. cordless drill with a 1/8 inch bit and a grease gun..I set pan under both drain valve and oil fitter..open valve. drill hole in bottom of filter. grease both drive shafts and front end..close valve.. pull already empty filter..fill new filter and put it on and fill from top..1/2 hour my oil is changed and my truck is greased...
Old Jul 12, 2007 | 08:28 PM
Red Monkey's Avatar
Red Monkey
Man, doesn't oil get all over your drill when you drill the filter? I just take a 'lady finger' and a hammer and tap a hole in mine. Draining the filter B 4 you remove it is the way to go!!
Old Jul 12, 2007 | 08:42 PM
ron's power stroke
nope..nice sharp drill bit..drill into from side of filter right at very bottom.not up into..soon as it pokes through pull it out..mabey half the bit gets oil on it...
Old Jul 13, 2007 | 09:09 AM
warrens250's Avatar
warrens250
Thanks for the help, Ron.
Warren
Originally Posted by ron's power stoke
Old Jul 13, 2007 | 02:03 PM
ernesteugene's Avatar
ernesteugene
See posts # 19 & 20 here https://www.ford-trucks.com/forums/631546-how-much-oil-does-my-psd-hold-2.html for two popular options.
Old Jul 13, 2007 | 05:31 PM
F250_'s Avatar
F250_
Here's another tip you can use instead of either punching or drilling a hole.
1. Get a 2-gallon zip lock bag
2. Place the bag around the filter up to the top
3. Unscrew the filter
*note* any spillage stays in the bag and your hands don't get covered either
4. Pour the filter into the catch pan where the engine is draining
5. Zip closed the zip lock bag
6. Toss the bagged filter in the trash.
