Quick answer please!
Old Jul 12, 2007 | 06:12 PM
tndiesel's Avatar
tndiesel
I'm putting in my new thermostat and of course didn't pay attention to the old when it came out. Do I put the little rubber washer on top of the stat after it's in or does it go first then the stat sits on top of it? It didn't feel right putting it in and letting the stat sit on top of it. My gut says it goes on top of the stat. I stopped and ate supper so this threw me off as well.
Thanks
Old Jul 12, 2007 | 06:21 PM
tjbeggs's Avatar
tjbeggs
Stat in water pump then 0ring then housing
Old Jul 12, 2007 | 06:25 PM
tndiesel's Avatar
tndiesel
You are the man! Do you use silicone for a thin layer around top of water pump housing to prevent leaks?
Old Jul 12, 2007 | 06:40 PM
tjbeggs's Avatar
tjbeggs
Yes I use a thin layer of silicone (RTV) around the thermostat housing neck. Otherwise it leaks.
Old Jul 12, 2007 | 06:43 PM
plowhand's Avatar
plowhand
Playing in the Dirt
You can, just make sure you don't use to much, you don't want it to squeeze out onto the thermostat.
