Question for you gearheads!!
Old Mar 15, 2002 | 01:16 PM
JimmyQB12's Avatar
JimmyQB12
WIll the installation of a Diablo chip in a 5.4L SuperCrew take the place of a FMU on a Supercharger? I think I have my terms right... WIll the chip in turn allow the right amount of gas instead of using a seperate fuel management system?
??? thanks
Old Mar 17, 2002 | 06:54 PM
canzus's Avatar
canzus
You'll still need the FMU, as boost
pressure increases, it needs more fuel
and the FMU will auotmatically do that.
The FMU uses manifold pressure to
control the fuel pressure...
Steve & the Rockette
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'73 MG B GT 2.6L V6(Ford)
'98 Contour SVT 2.5L V6 (Mods)
'01 ZX2 (No Mods yet)
Old Mar 17, 2002 | 07:51 PM
JimmyQB12's Avatar
JimmyQB12
Ok, fair enough... So then will the chip foul things up as far as providing too much fuel to the engine?
Does anyone have both a supercharger and chip installed?
Thanks,:-X11
Old Mar 17, 2002 | 09:07 PM
El Guapo's Avatar
El Guapo
not a big deal.
When you order the chip, you tell them what your engine modifications are.
They will then provide you a chip programmed with the correct parameters for your situation.
If you buy a chip before adding a turbo, then you add a turbo, then you'll need to get a different program. There are other factors involved besides fuel management, for example, ignition timing and advance under boost is a critical item and it needs to be right.
Old Mar 17, 2002 | 09:38 PM
JimmyQB12's Avatar
JimmyQB12
Ok, I'm a little relieved now... I bought a Diablo chip a month ago and now I'm really interested in a supercharger, but don't want to forfeit the chip.
Thanks for your help. BTW I know opinions vary on different superchargers, but what is everyone's pick for a good supercharger kit? I have a (SuperCrew 5.4L 4X4) I don't really want to spend over $3500 either.
Also, one more question... When all these mods are done to increase the amount of air that goes into the engine, and consequently increases performance; wouldn't you have to change the mass airflow sensor in order for the extra mods to matter?
Old Mar 18, 2002 | 05:27 PM
canzus's Avatar
canzus
>to matter?
Welcome to the wonderful world of electronic mods...
More than likely, you'll need to upgrade both. But that
depends on how much boost you're after. You'll probably
need to talk to the chip-burner, and the blower manuf.
to find out for sure. But I'd say, from experience, that
you'll definitely need a recalibrated, larger MAS...
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
Old Mar 18, 2002 | 06:55 PM
Lightning2Fast's Avatar
Lightning2Fast
dont use the chip unless its been burned with the blower in mind. and i wouldnt eliminate the fmu unless you have it dyno tuned without it. this is the only real safe way. and better if done right.
Old Mar 18, 2002 | 06:57 PM
Lightning2Fast
jimmy, vortech is the way to go for your application. www.vortecheng.com i recommend one highly. see signature
Old Mar 18, 2002 | 07:45 PM
nmaineron's Avatar
nmaineron
