should I buy it?
Old Jul 12, 2007 | 03:58 PM
spokanescouter's Avatar
spokanescouter
Exclamation should I buy it?
found a 2001 ford f250 extended cab v10 with163,000 miles
front tires have been moved to the back , tires show that the front end needs alignment, inner wear, the body looks good, the interior is good and was not driven by a smoker, cracked winshield, has a brake package after market, no fluids dripping...any ideas or questions I should ask...other than the normal questions?
Old Jul 13, 2007 | 05:52 PM
F250tuff's Avatar
F250tuff
You should post in the V-10 forum under Superdutys and ask some of the guys who drive them. I'm not familiar with the gas engines, but I do believe some of the earier V-10 engine were prone to blowing sparkplugs out of the heads.
Good Luck
Old Jul 13, 2007 | 07:08 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Depends on what you want. I would look at some psd's before ever buying a gasser. Depending on how much you will be driviing it, you could save enough in fuel cost between a gas and diesel to make the payments on a psd. If it needs a front end allignment, you will probably need some parts too. Check the color of the transmission fluid if it's an automatic.
stydel311
May 4, 2014 11:48 AM
Vijay
Oct 22, 2008 09:00 AM
Blacknav
Apr 1, 2008 01:23 PM
aklim
Mar 24, 2006 11:55 AM
weldingfreak
Offroad & 4x4
25
Jun 9, 2004 09:51 AM
