need fuel pressure sender help
Old Jul 12, 2007 | 03:29 PM
TNT in Round Rock's Avatar
TNT in Round Rock
I'm installing a fuel pressure gauge - the sender is a 1/8" NPT .. I'm planning to put it in the fuel bowl. Now somewhere I remember reading that you need an adapter for that - is that the case ? or is there a 1/8" NPT plug in the 7.3 fuel bowl ???
Old Jul 12, 2007 | 03:45 PM
nlemerise's Avatar
nlemerise
I have this install sheet, though it doesn't answer your specific question (my old brain cannot remember):
http://h1.ripway.com/nlemerise/Ford/fuelgaugeinstall.pdf
Old Jul 12, 2007 | 04:11 PM
TNT in Round Rock
well i'm thinking I do .. found one on Dieselsite and ordered my coolant filter so I ordered that too
Old Jul 12, 2007 | 04:15 PM
John311t's Avatar
John311t
A local Hydrolic shop can probably give you one, just bring in the plug, and the sender thats what i did and they gave me on with the oring.
Old Jul 12, 2007 | 09:24 PM
jtharvey's Avatar
jtharvey
I found mine at the local hardware store. I took the plug in with me to find the matching fitting. It did have a flared end on it that would stick into the fuel bowl, but I ground it off before I installed it. I think it was only a couple of dollars.
