Aerostar Ford Aerostar
Help Me Break The Codes
Old Jul 16, 2007 | 11:55 AM
WARedBear's Avatar
WARedBear
Question
About the ECT, are you sure you are using the correct connector for it? Aerocolorado had a similar problem recently. The correct plug is black in color, and there is another pinkish/brownish (heck, I can't tell the color anymore) but otherwise identical plug that's not used.
What are you referring to as the ECT? There are two wire connections for the tester. They are connected together by cap.
Reid
Spokane WA
Old Oct 6, 2007 | 08:41 AM
saiter's Avatar
saiter
i have a code 133 showing up and the engine runs rough no power and smells like gas like its throwing out the tail pipe or flooding
Old Oct 6, 2007 | 10:03 AM
96_4wdr's Avatar
96_4wdr
http://fordfuelinjection.com/?p=45
obdI code 133 is not valid for an Aero V6 ECU
what year and engine do you have?
try reading codes again
for a 93 Aero may be code 33 which is the EGR valve not opening
which can cause a warm engine rich fuel mix problem
http://autorepair.about.com/cs/troub...l_dtcs_37a.htm
Old Oct 6, 2007 | 01:08 PM
saiter's Avatar
saiter
i have checked the code 3 times its 133 the van is a 94 4,0 i back fires and stumbles when you give it gas and smells like fuel ive checked the coil pack and the edis6 it acts like its jumped a tooth on timming
Old Oct 7, 2007 | 08:02 AM
Aeroman59's Avatar
Aeroman59
You guys amaze me! (in a positive way!!!!)
Anyhow, the O2 sensor problem, do you have an exhaust leak near the y pipe or infront (closer to the engine) of it?
I say that because it sounds like your running rich due to over compenstaion by the ECU ,initialised by the O2 sensor which is reading a system lean condition.
Also if the ECT sensor is not giving the ECU 160* f, then the engine will effectively be running on choke for cold engine (engine may not go into closed loop fuel control).
Replace ECT sensor & make sure no exhaust leaks.
Aeroman.
Old Oct 7, 2007 | 08:43 AM
jamesaero's Avatar
jamesaero
saiter, the code you are geting is the first flash=1 telling you to get ready for codes. the next flashes are 111 then 111 again. system pass. try getting codes with KEY ON ENGINE OFF.
i had this same problem recently on a 94 3.0 and it turned out to be the ECT sensor. an easy $25 dollar fix. there is a way to check resistence on the sensor with a volt meter,but i dont know how. search forum.
jim
Old Oct 8, 2007 | 08:33 AM
saiter's Avatar
saiter
i tried the ect it did not work it idles fine but if you try to give it gas it pops and stumbles
Old Oct 8, 2007 | 08:55 AM
Bear River's Avatar
Bear River
Former ******
Ok, sounds like a MAF sensor problem to me. Disconnect the MAF sensor, and if it actually runs better, then there is something wrong with the MAF.
Old Oct 8, 2007 | 09:31 AM
saiter's Avatar
saiter
tried that it runs worse and set a maf code im lost at this point
Old Oct 8, 2007 | 11:25 AM
jamesaero's Avatar
jamesaero
saitor, the only other thing i "thought" was wrong was my fuel pressure regulator. i replaced it and the ect, disconnected the battery for 10 minutes and it was fine. hope this helps.
Old Oct 8, 2007 | 02:53 PM
saiter's Avatar
saiter
it was the maf when i had it tested it tested good but when i took it apart the 2 wires inside were filthy and coated with dirt thanks for the help guys
danielwd
1983 - 2012 Ranger & B-Series
Sep 16, 2016 12:04 AM
trooper T/diesel
18
Jan 29, 2014 03:51 PM
parr4
16
Dec 25, 2012 12:35 PM
aquaman
2004 - 2008 F150
Jun 28, 2012 07:48 PM
