Sponsored by: Real Truck
Gearing
Old Jul 12, 2007 | 09:06 AM
jmombo1321's Avatar
jmombo1321
Gearing
I have a 2005 F250SD 4x4 with 5.4L V8...and use it as an everyday driver and pull 5000lbs nearly every weekend...what's the best gearing to use...I believ I have stock 3.73, would it be worth going up to the 4.10? or more...
Old Jul 12, 2007 | 09:18 AM
redford's Avatar
redford
FTE Leadership Emeritus
It would help if you have issues with acceleration or climbing up mountain passes. From evidence other members have posted, it doesn't seem to hurt fuel mileage to step up to a 4.10 ratio.
I tow 8000 pounds (+/-) with my truck (see sig and pic) and don't have any major issues. Maybe the transmission makes the difference?
Old Jul 12, 2007 | 09:27 AM
one_wicked_element's Avatar
one_wicked_element
I've done some searching (but for the V10) and it seems you can go to 4.30's without hurting too much mpg. There isn't too much of a change from 3.73's to the 4.10's to make worth the money. That could just be the V10 though....
Old Jul 12, 2007 | 09:58 AM
redford's Avatar
redford
It isn't as subtle of a change as you might think. Just by going from a 3.73 gear set to a 4.10 gear set (no other changes) a 2007 F-250 5.4L 4x4 tow rating jumps almost 2000 pounds.
Old Jul 12, 2007 | 12:14 PM
BumperB's Avatar
BumperB
I went from 3.73's to 4.56's and noticed no MPG difference. I am getting anywhere from 10-13 mpg of mixed driving. I was really worried about going that low with stock tires but am very happy I did. At 80 mph I am just under 3,000 rpms. I ocassionally pull a 7,600 lb camper and it does okay for a 5.4L. I get anywhere from 7-9 mpg towing depending on the terrain.
Old Jul 12, 2007 | 12:38 PM
krewat's Avatar
krewat
Going from 3.73's to 4.30's is a 14% difference in torque to the ground. That's a big difference when you're pulling a load, or just driving around stop-and-go when empty.
Your towing and around-town MPGs should go up, or at least stay the same, not go down.
On the highway, the Ford modulars all seem to like more gearing and don't really care MPG-wise.
All in all, the 14% reduction (or thereabouts) in strain on the transmission is worth it.
I'm considering going to 4.56's myself, I currently have 3.73's and already went up one inch in tire diameter over stock.
Old Jul 12, 2007 | 02:26 PM
jmombo1321's Avatar
jmombo1321
Where's a good place to purchase the gearing for the F250SD 4x4
Old Jul 12, 2007 | 02:39 PM
redford's Avatar
redford
Randys Ring and Pinion is one place.
Old Jul 12, 2007 | 02:53 PM
BumperB's Avatar
BumperB
I definitely recommend Randy's Ring & Pinion. The place that installed mine recommended them as well. I don't know if you will beat their prices.
Old Jul 25, 2007 | 06:54 AM
DenF250's Avatar
DenF250
Unhappy Need Help
Hi everybody I'm about to by a F250 4X4 Long box XLT X-CAB.
But I Have to choose between two trucs about the same price the only difference one have 3.73 the other have 4.10 I will not really tow heavy load but I plan tu put a 2300 lb slide-in camper in it for the weekend the rest of the time is unloaded with half highway and half city use about 18000 m per year.
Which one should I choose.
Old Jul 25, 2007 | 07:00 AM
BumperB's Avatar
BumperB
The one w/4.10s
Old Jul 25, 2007 | 09:54 AM
krewat's Avatar
krewat
4.10's
You'll put less strain on the transmission driving around town and hauling the camper, and the difference in MPGs (if any) will be so small you'll never know the difference.
Old Jul 28, 2007 | 03:40 AM
DenF250's Avatar
DenF250
Thank you very much gent's I just got the 4.10 today your comments help me to make the decesion.
Old Jul 28, 2007 | 11:00 AM
edjunior's Avatar
edjunior
Congratulations. Enjoy.
