flushing
Old Jul 12, 2007 | 09:14 PM
Suber's Avatar
Suber
Tn, I would recommend that you let the silicone dry for SEVERAL hours, not one like I originally said. I have taken the assembly apart again as it leaks the second time around. I am going to let it sit overnight to dry then refill in the AM.
Old Jul 12, 2007 | 09:47 PM
tndiesel's Avatar
tndiesel
Well maybe too late. I did the back flush with the new stat in, hope that was o.k. The silicone had a drying time of almost 3 hrs.
Old Jul 12, 2007 | 09:51 PM
tndiesel's Avatar
tndiesel
Originally Posted by plowhand
I don't know if it will work I have never used it. I would wait and get some Ultra Blue silicone from NAPA or any other auto parts store.
Since you cannot get the block drain plug out, if you really want to flush the block good, I would suggest the following (I have done this alot and it works good).
Get a flush kit (it has a plastic "T" that you put in the heater hose and a connector for a garden hose). Drain the radiator and remove the lower hose. Install the flush kit, hook up the hose and turn it on. Let it run until the water is clear. Close the radiator drain and replace hose. Cap the flush kit "T" and fill the radiator with plain water and a radiator flush (garden hose water is fine). Drive the truck a couple hours or a day.
Repeat the drain and flush. Fill with plain water only. Drive the truck for a day or two.
Repeat the drain and flush and then fill with your 50/50 antifreeze mix and/or add the SCA. Your done. We do this on tractors and farm trucks where the block drain plugs has corroded and cannot be remove. It work good, just takes a bit longer to get everything out of the block.
I'm gonna be **** and drive with distilled water for a day the flush and do it again with distilled and flush, then refill with 50/50. Will the truck do anything different when I'm running just distilled water?
Also, I only have time to fill tonight and then I'm driving in the morning. Will it settle overnight and I should top off in the morning or should I take a gallon of water with me when I leave?
Old Jul 12, 2007 | 10:38 PM
tndiesel's Avatar
tndiesel
I just read your instructtions again. I don't have a radiator flush to add with the water. Is that o.k. to run water for a day, flush and repeat, then flush and just go ahead and add 50/50?
BTW, the T flush kit worked perfect! When refilling I left the top on the T open just a little and it pushed out almost all the air just like you said. It held 4 gallons of distilled water when refilling.
Old Jul 13, 2007 | 06:53 AM
tndiesel's Avatar
tndiesel
bump, bump
Old Jul 13, 2007 | 07:47 AM
plowhand's Avatar
plowhand
Playing in the Dirt
The flush helps loosen scale and deposits inside of the engine coolant passages. But yes you can just do it with water if you want to. Sorry about missing your last post last nite but.....I have to sleep sometime.
Old Jul 13, 2007 | 05:08 PM
tndiesel's Avatar
tndiesel
WEll the stat leaked so I drained entire system and siliconed both surfaces and will refill in the morning.
Old Jul 13, 2007 | 05:53 PM
tndiesel's Avatar
tndiesel
Is there a gasket that will fit between the water pump housing and stat housing? Seems that would stop the leaking but hopefully the silicone will. If there is a gasket you can put a paper thin layer on the gasket and that would be water tight for sure.
Old Jul 13, 2007 | 06:52 PM
Suber's Avatar
Suber
The only permanent fix will be to replace the long neck. That is the problem. You should be OK in the morning. Mine set up nicely overnight and I drove it quite a bit today without any leakage. I am going to replace the neck as soon as it comes in.
Old Jul 13, 2007 | 06:57 PM
tndiesel's Avatar
tndiesel
How much is the neck? Did you just put a thin layer on the neck and water pump where the two surfaces meet? On my cars there is usually a thin gasket that goes between stat housing and water pump with bolt holes for the bolts. Why don't these trucks have them?
Old Jul 13, 2007 | 07:22 PM
tndiesel's Avatar
tndiesel
Couldn't I get some gasket material and just make me one? Make one, thin layer of silicone on both sides, and then good to go hopefully.
Old Jul 13, 2007 | 07:59 PM
Suber's Avatar
Suber
I doubt you are going to have much luck fabbing a gasket. It is supposed to seal with the gasket that comes with your t-stat, providing that the flange end of the neck is nice and smooth, without corrosion, or wear. Unfortunately they get corroded and dont seal properly unless it is brand new. I put a nice bead around the waterpump surface and it has sealed just fine. You are NOT going to be able to get away with just a thin layer of silicone as has been suggested by others. I would not worry too much about the silicone getting onto the t-stat as long as you are careful.
In the end you may have to just get a new neck like I did. The positive to all of this is that will be ONE part closer to a Brand new truck!!
Old Jul 13, 2007 | 08:51 PM
  #28
tndiesel's Avatar
tndiesel
Well, I only put a thin layer on the stat neck and another thin layer on the water pump surface this 2nd time. Maybe those two thin layers will add up to enough. I did it at 4p.m. this afternoon and will not add water until 7 a.m. in the morning. If it doesn't work I'm gonna try a homemade gasket with gasket sealant. Where do you buy a new neck if needed?
Old Jul 13, 2007 | 09:49 PM
  #29
Suber's Avatar
Suber
http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=334
The price on this has gone up to 42.00. I just ordered one on Friday.
The Permatex may hold for quite a while and you may not even need to go further. I just did it as a tie-over until the new neck comes in.
Old Jul 13, 2007 | 10:13 PM
  #30
tndiesel's Avatar
tndiesel
So it still says $28 but it's actually $42?
