I am moving into the new house pretty soon and will have a nice sized 2 stall garage that is going to be my shop. There is currently 110 out there but I plan on sinking some conduit and pulling 110, TV, ethernet, data-bus for the alarm, etc. I also will be putting in some pipe for hot/cold water, air and gas as long as I have the trench dug. It won't be hooked up yet but I need to figure out how to put it in. The electrical part is taken care of, but I am no plumber. Can I run a 6" PVC pipe and run the others through that? Help me out here. Thanks.
It never hurts to go beyond the inspectors specs. I've spent my time in your part if the world. For the plumbing I would bury deep, use sch80 PVC pipe insullate extremlly well and wrap with a heat tape. I the building code is any stricter than than go with it. It does get cold up there. Don't beleive you can put the Elec. and the Plumbing in the same ditch. Be sure and ask that of the inspectors.
AFAIK, you can't put plumbing and electric in the same ditch. In your neck of the woods, you'd have to bury the pipe very deep, or shut it off when winter blows in. Your gonna need some place to drain that water to, also.
below the frost line approx. 4 to 5 feet for the water line. they make a heat tape now that you can insert inside the water line too, with a plug on the inside end for 110 v. It cost about $6 a foot. Mine comes up right at the well tank where it Tees to the outlet, and the pipe continues to the pressure switch. Talk to your city/county office for codes, as that would be the best bet.
A couple quick thoughts that I had regarding what you are planning. As was already mentioned, you should talk to the building inspector for what you HAVE to do versus what you WANT to do.
First of all, will the shop be heated and insulated? If it is, you wouldn't need to heat tape the water line as long as it is installed below the frost line. The local building code should be able to tell you what the minimum depth needs to be.
Also, since you want hot water out there, look into the cost effectiveness of putting a second, small water heater out there rather than running hot water from the house. Might be cheaper and would save a lot of water and energy depending on how far the run is from house to shop.
Finally, since you are going through all the effort of running conduit anyway, why not plan on putting 220 to your shop and installing a subpanel. 110 can be quite limiting.
That is a good idea to run the suppliy lines thru the 6" pipe. I am not sure how you are planning on getting the hot water to the garage though. I would install a small 10 gallon or some sort of insta heat in the garge rather than run a line for hot water from the house, seems to me running a hot water line from the house would be very inefficient.
Here in MD, you could use black well pipe, CPVC Plastic pipr or PVC plastic pipe for the supply. However you must use CPVC for the hot side.
if you are gonna run power out there as well as tv phone cat 5 ect you need a 1 foot seperation between the power and other lines I would put in two 2" conduits one for power one for eveything else you can put a lot of wires in a 2" pipe as long as you use long sweeps on the ends
Actually underground utilities are supposed to be 18" appart or further in the U.S.
Before you dig any trench.Call your utility co for a mark-out.Its free,just to make sure there is no cables,wires,gas...ect.In the ground were you plan on digging.
