I own a 2001 F-350, 7.3L, Dually, crew cab w/8' bed. It has 172K miles and going strong. My Reverse Sensing System turns off when backing. The manual says that it is a failure indication. Can anyone tell me what are the possible problems & solutions?
I know this sounds simplistic, but here goes. When you say clean the sensors are you refering to the outside flat surfaces of the sensors, or the components inside of the bumper?
Then I shelled out the $$ for one new sensor. Unplugged each sensor 1 at a time and replaced with new one checking at each step.
Still doesn't work. Any suggestions?
OOPS Mirror still works.
My grandmother would say,, "back up until you hear glass break"' and she did. Her car was totalled in her drive way without ever hitting another car. just the concrete walls lining her drive.
