tranns service
Old Jul 11, 2007 | 02:51 PM
big red c222's Avatar
big red c222
tranns service
I got my first tranny service on my 04 scab. 72000 miles. All they did was hook it up to the flush mach. They didn't drop the pan and change the filter. This was at a Ford dealer. It was about $150 which I though seemed cheap, so I looked closer at the receipt and that's when I noticed no parts just fluid. I went back in and asked. They said they just flush them. My Chrysler Concord was like $280, they do a full service. I'm glad it's cheaper, as long as it's the right way to do it. Any thoughts
Old Jul 11, 2007 | 04:01 PM
4DOORSR's Avatar
4DOORSR
I changed my fluid at 60k miles and I'll change the filter and fluid again at 100k. I've seen the filters come off with 40-60k on them and they're clean as a whistle.
Old Jul 11, 2007 | 04:44 PM
ranger88a's Avatar
ranger88a
If the filter on a trans is dirty you have bigger issues! The filter should be good and just flushing fine.
Old Jul 11, 2007 | 05:38 PM
jcsv99's Avatar
jcsv99
I had the same service done at the dealership at like 47K and it was the same thing, no parts just fluid. It ran me $199 and so far so good.
Old Jul 12, 2007 | 09:37 AM
osbornk's Avatar
osbornk
It will be fine. I got an early production Escape and it was the first transmission service the dealership had done on the Escape (30K in 10 months) and they found out the filter is not serviceable with the transmission in the vehicle.
Old Jul 12, 2007 | 02:47 PM
damone's Avatar
damone
The local oil change shop replaces filter/fluid/seal for less than a flush from the dealer.
Old Jul 12, 2007 | 03:11 PM
osteodoc08's Avatar
osteodoc08
More times than not they are just changing the fluid that is in the pan. That is only part of the total fluid. They'd have to drain the TC somehow to get rid off all the fluid.
It was nice when the TC had a drain plug, but AFAIK, the 2004+ trucks do not have it. My friends old Expy had a rubber plug you could pop out to access the TC drain. That was nice.
It is my understanding that the tranny filter is essentially there to act as a fine screen. It will not become "clogged" unless there was a catastrophic failure in the tranny, at which point the filter will not be of much use (to save the tranny). I, too, have seen filters out of the 4R70 tranny with 75K miles on it that were perfectly fine. A magnet didn't pick up much after I opened it.
In my wife's old Xterra, there was just a metal screen, no real "filter".
Old Jul 13, 2007 | 03:55 PM
big red c222
thanks for the input. I let those quick lube places do my oil when I don't feel like doing it myself, I would never let those guys get close to my tranny. I'm probably a better auto mechanic than some of the guy's that work at those places, and I'm an electrician. I also don't think they do the flush. I bet they don't get 2-3 quarts. Besides the fluid in the TC you also have the cooling lines and radiator. I try to avoid the dealer as much as possible, $$$$ some things, it's not worth chancing.
CdnWillyG
13
Aug 21, 2020 04:35 PM
benb123
Massachusetts Chapter
Dec 2, 2013 10:03 AM
7283-F250
New Hampshire Chapter
22
Mar 25, 2010 05:34 PM
Ciph3r
North Carolina Chapter
Feb 27, 2010 09:32 PM
Sport45
Dec 14, 2003 01:16 PM
