Vin Decode and HD brake question
Old Jul 11, 2007 | 11:30 AM
czaroc's Avatar
czaroc
Ok, Here's my vin
F25MKC55274
axle code C7E
Tranny A
WB 155
GVWR 8100
My problem is, the front axle code "E" comes up as invalid. What gives?
Also... Do I have HD brakes? Haynes says that HD brakes are on 250's and 350's with "higher" GVWR. That's kinda vague.
Old Jul 11, 2007 | 12:35 PM
aerobb's Avatar
aerobb
I'm guessing here but HD brakes is probably referring to dual piston calipers, pretty easy to tell if you look at the inside of the tires. Can't help you with the E code, is th BOM still on the Axle?
Old Jul 11, 2007 | 12:40 PM
czaroc's Avatar
czaroc
I think both reg and HD had dual pistons.
I have no idea where to look for the BOM on a 2WD front axle
Old Jul 11, 2007 | 04:46 PM
Jermafenser's Avatar
Jermafenser
8100 GVW = HD brakes.
6200-6750 GVW = Light Duty Brakes.
6800 GVW and above = Heavy Duty Brakes.
No such thing as "E"...maybe "B"?
Old Jul 11, 2007 | 04:56 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by czaroc
axle code C7E My problem is, the front axle code "E" comes up as invalid. What gives?
Doesn't come up invalid in my parts catalog.
C7 = Dana 60 / 3.54-1 / Limited Slip / 5300 lb rear axle capacity.
E (1976 only * ) = 3000 lb front axle capacity with power steering.
The parts catalog on CD was scanned from a very early printing, and is missing pertinent info. I'm using the latest actual Ford microfiche slides dated 10/88.
*There is a different E code used in 1979.
Old Jul 11, 2007 | 05:01 PM
czaroc's Avatar
czaroc
Sweet. Thanks.
Is it really a camper special? (crossing fingers) I'm starting to think it has the wrong badges on it.
No big radiator.
390 manual (not usual but still possible)
dual tanks might not be original
Old Jul 11, 2007 | 05:13 PM
NumberDummy
Ok, Here's my vin
F25MKC55274
axle code C7E
Tranny A
WB 155
GVWR 8100
F25 = F250 2WD
M = 390 4V
K = Kansas City Assembly Plant
C55274 = 1976
Trans A = New Process 435 4 Speed
155" Wheelbase
Gross Vehicle Weight Rating = 8100 lbs.
It's not a "Super Camper" Special, because those were only built on a 140" wheelbase. Only the Super Campers came standard with the Super Cooling radiator, Camper Specials had the extra cooling radiator. The Super Cooling radiator was optional. The core support IS different when the Super Cooling radiator was factory installed.
ALL 1976 and later F250 2WD's from serial number A75,001 have dual piston calipers.
What is the DSO code listed on the VIN plate?
Old Jul 11, 2007 | 05:20 PM
czaroc's Avatar
czaroc
I'm aware that it isn't a "super"... it's just a 250. and has the 155 WB.
Guess I thought the Big radiator was a camper-special thing. Just an Option then if it isn't super.
The only thing near the DSO spot on the VIN plate is "73" But it's offset by 1/2" or so
Old Jul 11, 2007 | 05:28 PM
NumberDummy
73 = Salt Lake City Ford District Sales Zone Office.
Where selling dealer ordered truck from.
NOTE: Added brake info to above ^^^ post.
Old Jul 11, 2007 | 05:32 PM
czaroc's Avatar
czaroc
So how do I tell if it was originally built as a Camper Special? Do I have to get a build sheet?
Old Jul 11, 2007 | 06:03 PM
Jermafenser
A dead giveaway is the dual battery setup...or what's left of it.
Old Jul 11, 2007 | 06:54 PM
czaroc's Avatar
czaroc
I'm not completely sure that the dual battery setup was original. looked pretty jerry-rigged
Old Jul 11, 2007 | 10:05 PM
Jermafenser
If it still has the driver's side battery tray, it's original.
The factory dual battery setup was simple and cheesy to say at least.
Some of the popular options on a 3/4 ton camper special were dual tanks, recreational mirrors, and limited slip rear axle.
Old Jul 11, 2007 | 10:16 PM
czaroc's Avatar
czaroc
could the dual tanks be a dealer installed option?
Old Jul 11, 2007 | 11:51 PM
NumberDummy
Not much of a chance of that...first off, the quarter panel is different. Not saying it couldn't be done, but from personal experience, I doubt any dealer would tackle that. Major reason, the cost factor to the customer. The price back then would have been at least $1500.00, about a fourth of what the truck cost new.
