filter houseing hoses
Old Jul 11, 2007 | 11:00 AM
caseydudem's Avatar
caseydudem
This is probebly an easy one for you guys. While I was cleaning the valley I noticed my hoses are cracked all around. The ones under the fuel filter housing. These hoses dont look like regular hoses. They look like maybe a high preasure hose. Where can we buy these? Does anybody know the size of the hoses. They look like maybe 3/8", but a pretty stout 3/8" hose.
Old Jul 11, 2007 | 11:34 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
I have been following the other post (the loosen bolt ) And I thougth I feel alone here in my Country because there are not to many PSD and parts, but in Germany it must be worse.
Here are the parts numbers for the THREE (3) hoses
Fuel Hose, BLUE (Aeroquip FC498-06)
(Ford) F4TZ-9324-CA, 3" Long lift pump to filter inlet
(Ford) F4TZ-9324-DA Shorter than above, Filter outlet to High Pressure (piston) pump inlet
They are 3/8, but You should need another 5/16.
It has to be rated at least for 250 psi and good for diesel, and some temp degrees (i dont remember) but someone chime in later.
Congrats, be safe, regards.
Here is another date for the hoses:
Aeroquip FC332-06 , 3/8" rated 250 psi, 17 bar. Same thing that ford will sell you in little packages, cost sky high. You need 3 little aeroquip hoses - 2 about 1 3/4" and one shorter, - the 1 3/4 " hoses are ford part # F4TZ-9324-CA , the part # on the shorter hose is F4TZ-9324-DA.fficeffice" /><O></O>
anything else that meets SAE J30R9 specs.<O></O>
Old Jul 11, 2007 | 04:07 PM
willbd's Avatar
willbd
RÖENTGEEP,
Do you have the part numbers for the return line fuel hose? One end goes to the uel regulator and the other to the left or right head.
Old Jul 11, 2007 | 05:44 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Maybe you can check here:
http://www.thedwilsons.com/powerstroke/PSD_Part_Numbers.html
Redmanbob
May 20, 2013 08:58 AM
84-250
Oct 17, 2009 02:58 PM
49willard
13
Jun 6, 2008 08:52 AM
crittersale
Jan 5, 2005 12:11 PM
fatherdoug
1983 - 2012 Ranger & B-Series
Jan 27, 2004 07:42 PM
