So after a very long time my clutch finally gave out on me...and before i get the "Have you tried chaning the slave cylinder?" the answer is yes its only a few months old ... i think its the actual clutch this time seeing as it is hard to shift and makes a horrible noise when shifting like it gets stuck when the clutch is pressed in so now its time to go ahead and put in a new one. The question that i have is the Clutch from the dealer my best route... i already have it priced out, but before i go for it im just wondering if theres anything better out there for me as far as name brand and if u guys have any suggestions on what i will need or any special tool i would appriciate the replys ... Thanxs again ppls
maybe everyones asleep ... Again any info would be greatly appreciated thanxs
For common stuff like a clutch this question has been re-cycled more times than can be counted easily.
Try the search feature near the top of this page and it will give you a ton of information.
ok so i tried the search feature for some clutch info and i got almost the same info you guys have posted either a Luk or a South bend with a kevlar pilot bushing ... but no clues as were to get the clutch from so if you guys could tell me were i might be able to get the best priced one that would be great ...
Kwik jus jumping off my own topic i took a look at ur gallery a while back and noticed u had a switch attached to the side of the shifter and another i belive behind ur pedal and since im new here jus wondering wats that for ...
Start of the day at work here, I'll come back tonight and give details. Short answer it's a device for adding power on demand.
Nice! well im going to go ahead and tear into the truck in a minute ...i found the south bend website only thing is it doesnt give any pricing info ... i guess in my case if i go with a performance clutch the Con O kit would work if its to much out of my price range ima have to go with the stock ...Sucks when u know there is something better out there
