FASS pump question
Old Jul 10, 2007 | 08:59 PM
John311t's Avatar
John311t
FASS pump question
My buddy sold his psd in favor of a 24vcummins(meh), it took his fass off his old truck before he sold it and wants to know if i want to buy it. $200 it has been used for about one year, its the 95gph pump, and it doesnt have the filters. What do you guys think? Im been kickin it around but im not sure if that pumps gonna be enough for what i want to do...
Old Jul 10, 2007 | 09:17 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
it will. unless............. what did you say you want to do
im sure it will flow plenty of#2.
good luck on the decision John
Old Jul 10, 2007 | 09:24 PM
John311t's Avatar
John311t
Lets just say this i want to smoke out a a 4 lane freeway! lol, im gonna put the dusted forged motor to the REAL test in about a year, its a slow building process, im startin on supporting mods. This past weekend one of the steel line on top of motors got rubbed through since it was hitting the intake manifolds. I did a temp fix of a piece of FI line in the bad area. I aint buyin that line from fords, and i gotta wait to make the lines for Regulated Return.
Old Jul 10, 2007 | 09:32 PM
PETE'S_6.0PSD
PMS PMS PMS LOL
well im getting there,
and which line you talking about? a fuel line?
Old Jul 10, 2007 | 09:49 PM
John311t's Avatar
John311t
Yeah, the fuel line running from the bowl to the rear of the head on the passenger side. I did not want to mess with it at my buddies house, since it looked as if my down pipe would have to be removed. So im cut the bad part out and used rubber line to replace the bad part. Yea PMS is a killa right now....I told him its gonna be at least a month or more until i can buy that pump, im just wondering now if thats a pusher pump, or a stock replacement. Im brewing my own RR to save cash.
Old Jul 11, 2007 | 03:32 PM
PETE'S_6.0PSD
John i might still have my old line somwhere after i did my regulated return, if i find it its yours,
ill let you know later after ill go look for it,
Old Jul 11, 2007 | 09:36 PM
John311t's Avatar
John311t
Sweet thanks dude!
You wouldnt happen to know about the fass pump being a replacement or a just a pusher pump?
Old Jul 11, 2007 | 09:46 PM
PETE'S_6.0PSD
its a replacement pump as far as i know, and i did find the fuel lines ill snap the pix for you and you tell me which one you need, they were outside for a while little rust on outside), so dont look perfect but no leaks, will need a little tlc and you be fine,
i could not get on the site for a while today, so ill make snapshot of the lines tommorrow and post it,
so ill talk to you tommorrow John
Old Jul 11, 2007 | 11:03 PM
FN74's Avatar
FN74
Originally Posted by John311t
Sweet thanks dude!
Just thought I would throw some tidbits your way. I have actually worked with them on some of the design aspects of the pump. The one from the Dodge will be little more than a pusher pump for the PSD. They are internally regulated, and for the Dodge, it will either be a 15 or 18 psi regulator spring inside. They are more than able to be a primary pump, but you will need to replace the regulator spring. Problem is, if you open up the pump it will void the manufacturer warranty. So a few options are, you use it as a pusher pump for the OEM ( a waste in my opinion), you send it in to DPP(FASS) and ask them to upgrade it to an 80 psi spring, or I can do that as well, and honor the warranty as well.
Old Jul 12, 2007 | 06:43 AM
John311t's Avatar
John311t
Its off his old PSD, so would it already have an 80lb spring inside? What is the warrenty on that pump?
Old Jul 12, 2007 | 09:58 AM
FN74's Avatar
FN74
DOH!! Guess maybe I should read a little more closely. It still will not have an 80 PSI spring though. Depends on what the kit was that he got. It gets pretty confusing real quick. They have about 20 different pump kits for the PSD, some are made to replace the OEM pump, some are made to assist the OEM pump. The HIGHEST pressure pump they sell for the PSD is a 60 PSI unit. Most of their PSD replacment pumps are only 50-55 psi. I don't like that, but they are basing it off of OEM spec for the truck, and spec is 51psi +-4. I don't like that regardless of spec so I custom order mine at 80 psi, which ususally comes out to be about 76psi. They track the serial number of ALL pumps, so if you let me know what the serial number is, I can likely find out exactly what pressure that pump was built at. More likely than not, it came with a 4 year warranty. They have recently bumped that up to 6 years.
Old Jul 12, 2007 | 12:21 PM
countrycar's Avatar
countrycar
FN74 Thanks for the info on the Fass Systems. I plan on doing one soon, this info is very helpful. Thanks Agian. Country
Old Jul 12, 2007 | 03:50 PM
John311t's Avatar
John311t
Thanks FN74, when i get the money to buy it i will give you the SN. Do you think 200$ is a honest price for it? Can you modify the pump to bring it up to 80psi? All i know is he paid like 400-450 for the pump, and they way he had it hooked up was to assist the stock pump, but IDK if it was designed like that or not.
Old Jul 12, 2007 | 09:01 PM
PETE'S_6.0PSD
here they are John,
i think you need the one on the left, one going to pass siderear head port? let me know if you want it, its yours, just s&h i hope you can use it, otherwise they go to dump,
Old Jul 13, 2007 | 06:23 PM
John311t's Avatar
John311t
Thats the one on the left! Ill take it off ya. You still got my address?
