Door locks
Old Jul 10, 2007 | 04:19 PM
wanness's Avatar
wanness
Cool Door locks
I have a `95 F-350, crewcab. the left rear door lock actuaor went out on it, I replaced it with an after market actuator. They sent the wrong linkage, I changed it to the original and the actuator worked about two months and went out again.
My problem is, the door is closed in the lock postition and I can't get it open to work on it. Any ideas? Thanks, Bill
Old Jul 10, 2007 | 04:22 PM
Skandocious's Avatar
Skandocious
Sorry, misunderstood your predicament. Yeah I would agree with the poster below, sounds like your old option is to pull the seat. The key won't open the door from the outside? That mechanism doesn't involve the electric actuator. Now if you're linkage is incorrect then you could have problems...
-Chris
Old Jul 10, 2007 | 04:25 PM
GRAVEYARDSHIFT's Avatar
GRAVEYARDSHIFT
You might be able to just remove the door pannel if you pull the seat? Pat
Old Jul 10, 2007 | 06:23 PM
kermitthefrog's Avatar
kermitthefrog
The rear door doesnt have a key lock.
You can PULL the door panel real hard. but the clips holding it on will prbably break since you cant pry the panel. Did you try to use a 'slim jim' through the window and the weatherstrip to open it?
Old Jul 11, 2007 | 05:10 PM
wanness's Avatar
wanness
Locked door
I appreciate all of the suggestions.
Her is what I did to get the door open;
I was able to reach around the side of the seat and screw the three phillips head screws out of the door, screwed the handle screw out and was able to pop the right side of the door panel out. Then I pushed the seat forward as far as it would go and was able to reach under the panel on the left hand side and pull it out. After removing the panel, I could then reach the two pieces of linkage to open the door. Now, what I am wondering is, does any one have an easy way of pulling that actual solenoid out of its bracket. I don't really want to drill out the solenoid bracket again. Thanks, Bill
cowboyteddybear
Feb 19, 2013 05:54 AM
joe71190
1997 - 2003 F150
Mar 26, 2009 02:13 AM
TAA
New Member Introductions
May 20, 2007 01:27 PM
captfillet
Electrical Systems/Wiring
Mar 4, 2006 05:48 PM
