Sponsored by: Auxito
Electrical Problem, Related to Windows-Help
Old Aug 10, 2002 | 07:24 PM
tealboy1's Avatar
tealboy1
Does this situation sound familar? My windows will intermitently fail to go up. Seems like they always go down, but occassionally, for no apparent reason, I can't get them to go up. I will repeatedly mash the "up" button and turn the ignition off and on, and no luck. Then, all of a sudden, the window goes up. I have been observing this situation for several months trying to pattern the problem, but I can't seem to identify a pattern. However, the problem has become more troublesome of late, as the frequency has increased.
Does anything about this sound familar? Any suggestions on how to repair or troubleshoot would be appreciated.
dave
Old Aug 10, 2002 | 07:30 PM
94van's Avatar
94van
[updated:LAST EDITED ON 10-Aug-02 AT 08:31 PM (EST)]I've had this problem in the past when the buttons are mounted on the armrest. Dirt and stuff seems to get down in the switch and causes it to be intermitent. I have sometimes blown into it with an air hose to get it to work, sometimes have to pull the switch.
http://easyad.net/images/94vanavitar.jpg http://www.easyad.net/images/mustang1.gif
'94 E-150 Conversion Van 4.9 / C-6 -- '89 Mustang LX 5.0
Old Aug 10, 2002 | 07:35 PM
tealboy1's Avatar
tealboy1
I should have added the following. The windows affected are fronts and rears, and it does not matter which buttons I use. For example, if I reach back and hit the rear window button, it still won't go up. Likewise if i reach across the truck and hit the passenger button. Still won't work.
Old Aug 25, 2002 | 01:07 PM
tealboy1's Avatar
tealboy1
Situation is now worse. Three of my four windows are stuck down and I can't get them up. As indicated above, I could usually get them to go up but no longer. I really don't think this is a switch issue b/c like i said, I can hit one of any of the other three window switches and nothing happens. I have checked the owners manual relating to switches/windows, etc. and could not find anything window specific.
Pls help!
Old Aug 25, 2002 | 01:33 PM
warfalcon's Avatar
warfalcon
Post Electrical Problem, Related to Windows-Help
roljr
Aug 31, 2012 11:30 PM
TNVOL
Jul 11, 2010 11:04 AM
fortmac
Sep 13, 2005 04:50 PM
Triphicus
Bronco II
25
Feb 2, 2005 03:16 PM
Darth Baiter
Jun 2, 2003 02:57 PM
