Sponsored by: Auxito
Please Help Me
Old Jul 10, 2007 | 08:26 AM
REDNECKBRONCO96's Avatar
REDNECKBRONCO96
Please Help Me
I have a 1997 ford f150 with a 4.6 in it the trucks odometer stopped running two years ago and it says 256,000 but I replaced the motor and it know only has about 85,000 and I just got the transmission rebiult after telling you guys all that I have been having a problem ith the way the truck has been running under a normal aceleration it would buck and at cruise ing speed it would do the same thing (45-60mph) so I changed the plugs, wires, both coils, air filter, fuel filter i did all this because the check engine like came on and it said #7 cylinder miss fire after I found that out I just changed that plug and wire and coil because I was broke and it ran a little better after I did that it ran a little better then it came up that #3 cylinder miss fired so thats when I changed every thing and it is doing the same thing what do I do please help
Old Jul 10, 2007 | 10:33 AM
KingRanchMan02's Avatar
KingRanchMan02
Welcome to FTE Redneckbronco96.
What brand parts did you use when you changed the plugs and wires? These engines are pretty sensitive and seem to run best with Motorcraft parts. Good luck!
Old Jul 10, 2007 | 01:00 PM
REDNECKBRONCO96
bosch platnuim and professional
Old Jul 10, 2007 | 01:44 PM
KingRanchMan02
This is a much discussed topic. The vast majority of FTE members, myself included will recommend using only Motorcraft plugs and wires.
Do you know what brand parts you took out when you changed these parts?
Old Jul 10, 2007 | 05:46 PM
dieselbogging's Avatar
dieselbogging
I put brand new bosch 8mm wires and NGK platinum plugs and i have to say that i disagree. She runs better on these than the motocraft brand. hmmm....
Old Jul 10, 2007 | 07:38 PM
LxMan1's Avatar
LxMan1
Bosch plugs do not run well in these engines. NGK is a much better plug than a Bosch.
Old Jul 10, 2007 | 07:43 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Hell...my buddie's Dodge Ram (5.9L) had problems with Bosch plugs...
Old Jul 10, 2007 | 07:56 PM
countryboy116's Avatar
countryboy116
i have bosch plugs in mine, stick with the motorcraft, its not a huge thing and theres not one particular thing i can put my finger on but it just doesnt run as good with the bosch, my dad put them in when he had it otherwise i would have put in motorcraft, just dont have the time to change them out right now or the money to have someone else do it lol
Old Jul 11, 2007 | 09:26 AM
REDNECKBRONCO96
well a code came up and it said miss fire in cylinder 3 so I changed the injector and got most of everything back to normal but i noticed half way to work when I was stoped it felt like a miss fire once every 10 sec or so do you think I should clean all of my injectors or what thanks for all your help
