Bed liner question
Old Jul 10, 2007 | 12:09 AM
J. Frank's Avatar
J. Frank
Bed liner question
Hey guys i have a quick question. I have some light surface rust in the bed of my 1972 f250 longbed. I am planning on putting in one of those do-it-yourself bedliners. Do i need to contain the rust before i put the bedliner on?
Old Jul 10, 2007 | 10:13 PM
f2501967's Avatar
f2501967
yes you do, is it surface rust, or has it eaten away thru the metal. if it is surface rust just sand down to bare metal, and primer the area. if it eaten thru cut it out about 1-2" around the infected area, then weld in a piece of metal, then primer the area. if you cant weld you can pop rivet a new piece in and use metal type bondo and sand smooth and primer. that is what i would do.
Old Jul 11, 2007 | 05:56 PM
J. Frank's Avatar
J. Frank
I only have surface rust. I'll go ahead and do what you said before i put the bed liner. Thanks for the tip
5spdxlt
2004 - 2008 F150
Jul 23, 2015 02:41 PM
Jeremy Kamutzki
Apr 29, 2015 02:19 PM
metriccar
2009 - 2014 F150
Jul 17, 2014 08:58 AM
Neaonbhb
Jul 26, 2012 12:48 AM
mooktank
Paint & Bodywork
Feb 17, 2003 01:56 PM
