Sponsored by: Real Truck
Torque Steer?
Old Jul 9, 2007 | 03:33 AM
eodmule's Avatar
eodmule
Question Torque Steer?
What I originally thought was just a really bad wonder, now I see a pattern.
When I get on the skinny pedal, my 2000 F350 (turbo-7.3 and a manual trans) pulls to the left. Hard enough that if I'm not watching what I'm doing, I'll "accidentally" change lanes.
When I left off, it pull to the right just as hard.
Driving like a semi-normal human it is not as noticeable.
I'm stumped as to what it could be. I know the shocks need to be replaced but I can't just throw money I don't have at it until I fix the problem by pure luck. What should I be looking for?
Old Jul 9, 2007 | 03:41 AM
F250tuff's Avatar
F250tuff
Could one of your front hubs possibly be locked-in?
Old Jul 9, 2007 | 03:52 AM
eodmule's Avatar
eodmule
Nope, both are unlocked. I thought that might be it but when I checked they were unlocked.
Old Jul 9, 2007 | 04:02 AM
F250tuff's Avatar
F250tuff
Can you reach behind the wheels and spin the front drive shafts freely?
I'm not second-guessing you, but this has been an issue many times for others. Check this post:
https://www.ford-trucks.com/forums/6...be-locked.html
Old Jul 9, 2007 | 04:27 AM
eodmule's Avatar
eodmule
Yeah, I have manual locking hubs. They are both unlocked and the front shaft moves freely.
I was looking at that same thread a few days ago. Sounds like a vacuum problem taking too long to unlock the auto hubs.
Anyway, like I said the shaft spins freely and the hubs are unlocked but thanks for the help so quick. I work graveyards so I'm on late at night.
Old Jul 9, 2007 | 06:12 AM
ken75ranger's Avatar
ken75ranger
Check your sway bars.
Old Jul 9, 2007 | 07:31 AM
Soilman's Avatar
Soilman
Torque steer can be a problem with light weight drag cars, but these SD's are far from that, so unless you a engine modification you ain't telling us about it shouldn't be that.
I would be looking at the rear axle. Are the leaf spring bushing in good shape on both sides of the truck? Are the u-bolt tight on both sides? Can you see where one side has shifted a little? Is the truck dog tracking at all ( back not following the front )? I wrecked a truck and bent the frame, the shop said it was perfect when they finished but it still did what you are discribing.
The rear diff could be acting up? Is it LS or open? It will do that with a broken axle on one side, but you should know if that has happened. Get a four wheel alignment and see what happens. That is cheaper than shocks to start of.
Old Jul 9, 2007 | 08:17 AM
redford's Avatar
redford
FTE Leadership Emeritus
Check to see if you have a broken motor mount.
If not, also check your rear axle area like soilman says.
Lastly, are your rear tires all the same size?
Old Jul 9, 2007 | 08:31 AM
johnnysF350's Avatar
johnnysF350
Check to see if you might have a sticky brake caliper???
Old Jul 9, 2007 | 12:28 PM
F250tuff's Avatar
F250tuff
You may have something loose on the front or rear axle. Probably the only way to check the front it to crawl under it with a pry bar and check every link/bushing for slack. For the rear axle, you could lay on the ground (a safe distance away), have someone else sit in the truck, and they could torque-up the rear axle (hold the brakes while giving it a good bit of gas like they were going to power-brake it), while you look to see if the axle is shifting.
Good luck.
Old Jul 10, 2007 | 05:15 AM
eodmule's Avatar
eodmule
I get off work this morning so later this afternoon a pry bar, hydraulic jack, some 2x4's and myself have a date with the underside of my truck.
I'm hoping it is something semi-easy to fix.
Thanks for all of the quick responses.
Old Jul 10, 2007 | 01:25 PM
Casey's Avatar
Casey
It sounds like something is letting the driver's side of the rear axle move fore and aft. That's where I'd start looking for something loose or broken.
Old Jul 11, 2007 | 01:49 AM
eodmule's Avatar
eodmule
I tried to get out there today but it was almost 100 freakin' degrees!
Some of you southern folks may be used to that temp, but up here in the northwest it's way too much.
Hopefully tomorrow before it gets above 85 (around 9:00am) I'll give it a try and see what's going on under my truck.
Old Jul 11, 2007 | 03:07 AM
RIsuperduty89's Avatar
RIsuperduty89
good luck tomorrow, hopefully you find the problem... to me it does sound like something is sticking causing one side to move towards a certain direction.
Old Jul 11, 2007 | 03:33 AM
eodmule's Avatar
eodmule
Thanks, I hope it goes well also. I just really hope it is cheap to fix!
