Radiator size question
Old Jul 8, 2007 | 08:43 PM
79f100six's Avatar
79f100six
Ok i was getting a new radiator for my 78 f250 351m that i am putting a 400 into in a few days, and right now i have the standard 19 1/4 x 26 1/4 x 2 1/4 stock radiator. Could i put the taller 460 type radiator that is 5 inches taller without any modifications or buying anything, or would i have to buy something. Since my truck will hit between 230 and 240 degrees while muddin and that is not turning over many rpm's.
Old Jul 25, 2007 | 10:18 PM
amish77's Avatar
amish77
It will fit, but the hoses will need some adjustment. I'd go with flex hoses for a universal fit.
Old Jul 30, 2007 | 06:17 AM
fatherdoug's Avatar
fatherdoug
I put the larger radiator from a 460 into my '78 F-150 with a 400. The only adaptation I had to make was the lower radiator hose. The upper hose is the same. You will want to use the lower hose for a 400 with a supercooling radiator. The lower part of the radiator still does not extend beyond the cross brace on the frame, which is a good thing. You will also need the larger fan shroud, which is a D7TA-8146-SA(Bronco Graveyard part # 20624)
F250_
Sep 10, 2015 08:45 AM
Panhead55
Aug 22, 2015 09:04 PM
winginit
Jul 14, 2015 10:31 PM
phoskins
Jan 12, 2015 08:20 PM
Traveller76
Sep 10, 2013 07:05 PM
