oil pressure problems?Try this first!
Old Jul 8, 2007 | 04:22 PM
raw2619's Avatar
raw2619
Have a 1986 F150 302 EFI.When the truck was cold,the oil pressure gauge went up about three-eights of the way.As it warmed up,the gauge would drop to low.I figured I was losing the bearing clearances....I expected the worse...but I thought I'd try a new sending unit first.It took all of 2 minutes to replace it(it's right above the oil filter)and now the gauge is where it should be....right in the middle!Hot or cold now,it's working great.....a lot easier than jacking up the engine!
Old Jul 25, 2007 | 10:00 PM
amish77's Avatar
amish77
Yeah I had a similar problems until I changed my sending unit. I think the old ones have a diaphragm in them I think. Not sure why the new ones go out.
Old Jul 25, 2007 | 11:50 PM
Mil1ion's Avatar
Mil1ion
Engine or material particle can get lodged inside the Tiny orifice of the S/U and cause a low pressure reading.
Old Jul 26, 2007 | 11:49 AM
amish77's Avatar
amish77
Gotcha. makes sense.
Old Jul 26, 2007 | 12:15 PM
stumpbuster's Avatar
stumpbuster
Cool!
big fan of quick fixes.
Old Jul 26, 2007 | 02:48 PM
gdgerland's Avatar
gdgerland
Smart move!!!!
You got it right that time Bud. Had the same thing happen on my I-6 except my oil pressure stayed a "0". Changed the transmitter and all is well. My motto is check the easy (cheap) things first.
