just put a herculiner in my f250 worked out really well i also had some left over to start to undercote the truck. i had a rino liner in my last truck i liked it alot it just cost so much to have it put in. so i went with this stuff and saved some bucks. i tryed it for the main reason of rust. the bed was starting to get scrached up so i wanted to coat it. it cost me 75 bucks but i can put more then one coat on. for all you do it your selfers out there this is vary simple and cost vary little to do. just my 2ct
I though of doing the same thing you did to my truck, but I didnt want to put it over the dents in the wheel wells and I REALLY didnt want to beat them out. I have a cap on the truck so I dont have to worry about rust that much. Im glad to hear you like the stuff and I hope the it works out for you.
Could explain what went wrong with the bed liners you put on? I am about to put one in and want to do it right.
Well lets see, first one chipped off after about a year. Second one adhered a lot better but eventually faded and came off with use. The DIY kits are never never as good as spray on's. I also talked to a master mechanic friend about this and he agreed with me as well, the DIY kits aren't that great.
However, I would use them in smaller applications such as floorboards (who really needs carpeting?) and places that aren't always exposed to weather and heavy use.
Any DIY product for a bedliner with the exception of Zolotone should have a hardener or it doesn't belong in your truck bed. If you put a jug of gas in your bed and it leaks out it will melt a single part product such as Herculiner. Also, chalking will occur very fast because of lack of UV protection also because of a lack of hardener. We sell a few different brands of DIY bedliner that alot of our customers use in truckbeds, engine bays, frames, and trunks. It runs about 70 bucks for a kit, comes with hardener, can be rolled brushed or sprayed, and the kit will do a small truck bed. SEM, Dominion Sure Seal, and Morton all make the stuff and it all works great.
