I personally feel that you should spend your money in other areas before jumpin into big turbo's. You'll need fuel to run those bigger turbinators, and you'll need a good tuner to run bigger fuel sticks, and you will need a stronger HPOP when you start putin big sticks into the motor.
oh ya im goin to do all that stuff but i wanted to research all the turbo stuff b4 i ordered all that but im goin to order all tht. wht do u mean better tuner?? im running a dp tuner with jus a 140 extreme and 60tow programs wht do u suggest for programming
You add your bigger sticks and other mods you'll have to have your chip reburnt to run correctly with all your mods, Atleast with your bigger sticks to get them to run right.
oh ok i got ya my bad i guess i misread, so you think ill be good runnig tht tuner with all that boost and fuel?
You need to call and talk to Jody at DP, tell him what you are doing and he will have to reburn your current tunes to control all the new stuff. Also look into VanAacken bros. racing they also have a nice twin kit.
VanAacken brothers have a sweet 6.0 VGT kit that adapts a VGT unit to our trucks. Supposed to be pretty sweet. I have been meanin to call them and see what it flows compared to my D66.
who makes and sells twin turbo kits for 7.3's??? i just ordered my injectors and will be ordering an bts tranny so the turbos are next.. im searching for mid 12's and i believe its posiible with twins,propane,and nitrous and everything else i have.. someone please chime in and lemme know what you think thanks guys
ditch the propane and just run nitrous. A good single turbo and nitrous will put you in the 12's, but your stock engine probably wont last very long at those power levels. If you really want twins talk to the guys at BTS they have a sweet twin setup.
ya im prolly goin to run a sinlge setp with jus nitrous. are you runnig any water inkection or anything like that? also who makes a good turbo like that? i know of turbonetics but what type of turbo are you guys in the 12's and 11's running?
Nope no water or nitrous at this point. Im running a turbo from www.beansdieselperformance.com its pretty big and is capable of supporting 600 on fuel.
