Temperature range
Old Jul 7, 2007 | 05:31 PM
jetdoc's Avatar
jetdoc
Temperature range
Does anyone know what temperature range our ZF-6 and transfer case and rear axle operate? I have a spare Autometer 4355 water temp gauge 100-260 degree. Will I see hotter temps than 260? I want to rig this up with a rotary switch and a sender for each. Thanks in advance!
Old Jul 7, 2007 | 11:34 PM
jtharvey's Avatar
jtharvey
I wouldn't imagine that either of them would run hotter than 260. The engine oil doesn't even get that hot, with all the moving parts and high pressure explosions going on in the cylinders.
Old Jul 8, 2007 | 02:38 PM
Fat Diesel's Avatar
Fat Diesel
I've seen about 200* in the 6 Speed and about 40* lower in the rear on a hot day going fast on flat ground.
Check out this post I did about putting two sending units on one switch.
https://www.ford-trucks.com/forums/6...iff-cover.html
Old Jul 9, 2007 | 06:00 AM
jetdoc's Avatar
jetdoc
Actually it's what gave me the idea for it! Now I just need to call Autometer for the temperature probes.
ericconn
Mar 26, 2014 08:17 PM
SkySkiJason
21
Mar 11, 2009 07:10 AM
proteks
17
Dec 14, 2004 12:35 PM
Rick Pry
Jan 23, 2004 01:05 PM
JimS
Aug 27, 2003 06:22 PM
