por-15 WOW!!!!!
Old Jul 7, 2007 | 04:14 PM
dryfly's Avatar
dryfly
Thumbs up por-15 WOW!!!!!
All I can say is wow.This stuff is incredible.I just finished my third coat on my oil pan,overkill really,and I dont think I have to worry about my oil pan ever again.I started a thread a little ago about other options but I'm glad I took your advice.I bought the starter kit from thier website($18).Came with everything I needed rite down to the rubber gloves.Side note:You do need the two chems that come with it,I wasnt sure at first.One says marine.Anyway the instructions are very well written.The process is easy and it comes out looking great.More importantly it doesnt look like any salt or anything else is going to get at my pan.I'm so impressed I'm going to order a gallon of the stuff and do the whole underside.Oh and by the way the starter kit comes with just a 4oz. can.Was a little worried about haveing enough.Well it turns out I only used half of that and I put it on a little thiker than I was supposed to.I also took the advise of one of you to put a surgical glove between the lid and can to seal it up better,good idea to whomever came up with that idea.So if you were on the fence about the stuff get off it and buy.good luck and thanks all for the advice.
Old Jul 7, 2007 | 04:39 PM
ron's power stroke's Avatar
ron's power stroke
glad you got it fixed...you got a link??? i just may do my oil pan..isnt rusted yet..my truck came from the south...but i live in a very snowy state..we use a lot of salt up here.might as well use it now rather then wait for it to rust..thanks...
Old Jul 7, 2007 | 04:41 PM
Green_Dually's Avatar
Green_Dually
Did you wire brush the oil pan any.Im going to do mine tommarow with the same stuff.I know i need to get rid of the loose stuff,but what about the rust,just go over it?
Old Jul 7, 2007 | 05:04 PM
dryfly's Avatar
dryfly
you got a link???
yes here;
http://www.por15.com/s.nl/it.A/id.1404/.f
thats the kit I used
Did you wire brush the oil pan?
Yes.first I simple green and scraper.Then I wire brushed and wire wheeled it with my grinder and wire wheel installed on it.Then I used the chemicals and followed ther directions completely.Grad somed 200 grit sandpaper from the hardware store.For the painted surfaces.I did the whole pan.It sounds like more than it is.It was really simple.Good luck
Old Jul 7, 2007 | 05:08 PM
ron's power stroke
thanks for link
Old Jul 7, 2007 | 09:36 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Just a note about the surgical glove trick, an easier trick is to turn any paint, glue, whatever can upside down. The material inside then seals around the lid to keep air out and the solvents in. I do this for paint, PVC glue, liquid tape, etc...When you do this the stuff last almost forever on the shelf. Glad the Por-15 worked so good. I'm trying to decide between that and Rust Bullet for the frame and parts on my rat-rod '55 F-100.
Scott Stewart
25
Jun 8, 2023 11:39 AM
mark1986F150
Mar 13, 2015 08:52 PM
Raymond
18
Dec 8, 2011 07:59 PM
Baradium
22
Jan 9, 2007 07:10 PM
59INA40
Nov 27, 2005 04:37 PM
