2000 e350sd tranny adjustments???
Old Jul 7, 2007 | 01:09 PM
mikekin1's Avatar
mikekin1
Angry 2000 e350sd tranny adjustments???
hey guys are there any other cable adjusments on the tranny shift cable other than at the tranny made an adjustment at the tranny to get truck to start in park,(thought it was sensor but was wrong) and now it doesnt go into first gear from the column. just wondering if there is another adjustment somewhere in side the cabin??
also when the truck "rolls into park" it will not start in park. have to set brake for it to start in park.
Is this a cable adjustment or is the range sensor really $#!!ing the bed??
was told that if range sensor was bad it would not have any gears
any suggestions welcome
tia
Old Jul 8, 2007 | 09:17 AM
Casey's Avatar
Casey
A bad range sensor won't cause any of the problems you're seeing. Your cable is mis-adjusted.
Shadow351
1997 - 2003 F150
Mar 15, 2016 05:55 PM
kdaug5
Nov 30, 2015 10:49 AM
crazymut
18
Aug 10, 2015 02:29 PM
cub102
Jun 11, 2015 10:01 PM
kent521
Apr 12, 2011 11:12 AM
