Hello...New Member needs leaf spring help
Old Jul 7, 2007 | 12:17 PM
ronquillaw's Avatar
ronquillaw
Wink Hello...New Member needs leaf spring help
Hi,
I own a 2000 Excursion V10. 2 days ago I slammed on the brakes to avoid a collsion and heard a crack. Subsequently there was a metal on metal noise that I just discovered was a broken front right side leaf spring. The top leaf spring broke at the point where they are held with a metallic band. I am considering replacing it but I have some questions before I get into the process. Any help would be Greatly appreciated.
Questions:
1. Where is the best (cheapest) place to buy replacement stock leaf springs?
2. Must I replace both leaf springs?
3. Is this a job I should do myself?
4. Can I drive it around with a broken leaf spring till I get the parts delivered?
I appreciate any responses and additional comments or points I should know.
Thank you
Old Jul 7, 2007 | 12:23 PM
jackrista's Avatar
jackrista
do not drive with a broken leaf spring. if you do any towing think about swapping in truck leafs. find a 4x4 shop that does a lot of lifts and ask them about the springs they take off trucks when they lift them. and replace both leaf springs. always in pairs.
Old Jul 7, 2007 | 12:44 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Dont drive it and mambe think about a lift kit while you at it. Just my two cents
Nick
Old Jul 7, 2007 | 01:40 PM
Aatcntrl1's Avatar
Aatcntrl1
It shouldn't be to hard to find someone that lifted there truck and is in need of more garage space. Check Forums, some will even let you post that you need something. Otherwise, if you want to buy new than a little lift is always nice.
I would never drive a truck with a cracked spring. Like most things it will totally fail when you need it most.
The installation of leaf springs is pretty straight forward. My truck was already lifted when I bought it so I can't comment from experience. However a buddy said he was watching his F250 being lifted and commented to the Tech that the new leaf springs were "U" shaped. How would they ever fit. Well he showed him. He bolted one side to the shackle and then bascially let the jack down, until the weight of the truck stretched the spring out. Pretty Cool Trick.
Old Jul 7, 2007 | 02:11 PM
housedad's Avatar
housedad
Originally Posted by ronquillaw
Questions:
First, Don't drive it at all. Your top leaf is the main leaf. If that is broken no end of bad stuff can happen on the road even going to the shop.
Answers (my opinions)
1. Dealer or boneyard. Or you can ask on this forum for anyone that changed their springs and will give or sell you the old ones. The only other option is to change to the truck springs.
2. Very wise idea, but not neccessary. Remember, though, the force that broke the one spring also impacted on the unbroken one. It may have weakened it or put cracks in it.
3. If you are reeasonably mechanically inclined and have the tools. Save a grunch of money. Use quality jackstands and chocks.
4. NO NO NO
Old Jul 7, 2007 | 02:49 PM
Monsta's Avatar
Monsta
Sit. Stay.
You mean left and right or all the springs in the pack that had one break? Don't matter really...you gotta (should) replace BOTH your springs packs in the front. Otherwise your truck will sit un-level due to the new spring pack on one side and the worn one on the other.
Many suggest V-codes. Here's everything you need to know about doing that swap yourself. Keep in mind that you'll need to raise the rear to keep the truck's stock rake. Add-a-leafs are better than adding blocks, IMHO.
http://www.supermotors.net/clubs/for...stry/9/54681-2
Old Jul 8, 2007 | 12:09 AM
ronquillaw's Avatar
ronquillaw
Thanks for the advice.
A few more questions.....
5. What are V-code leafsprings compared to the stock ones?
6. Are the leaf spring I have now different from "truck" springs?
7. "you'll need to raise the rear to keep the truck's stock rake" .... What does that mean? Will I have to raise the rear after I repace the front leafs??
I really appreciate all the help and after all the coments I think I just about got it.....
I will update you on all my progress............Thanks for helping the newbie.
Old Jul 8, 2007 | 12:29 AM
aklim's Avatar
aklim
5. My stock ones are D for the front and G for the rear. V codes are a bit stiffer
6. Yes they are softer and sit lower.
7. The front will come up a couple of inches. So, to keep the same angle where the rear is higher, you will have to raise the rear too. In my case, I changed the rear 2 in blocks to 4 in blocks after I went to U fronts and A rears.
Old Jul 9, 2007 | 03:22 PM
ExcursionDad's Avatar
ExcursionDad
Ronquillaw - Looks like we might live pretty close to each other. I just removed my stock front springs 3 days ago and would be willing to part with them for free if you don't mind coming to get them. PM me if you're interested.
Old Jul 9, 2007 | 07:58 PM
dizzy d's Avatar
dizzy d
Look on e bay 4 some F250 or 350 springs you might be able to find all 4 and it will tow much better.
david9dr
Oct 5, 2016 01:48 PM
Amicus
Feb 8, 2016 07:08 PM
Sous
20
May 11, 2015 07:37 AM
jimcar-9
Oct 31, 2014 12:36 PM
Hometown Pride
16
Sep 2, 2009 04:13 PM
