Off the line....
Old Jul 7, 2007 | 02:23 AM
outlaw219's Avatar
outlaw219
Off the line....
Hello everybody,
I've got a '97 4X4 7.3 with a mild Superchip and straight-piped exhaust and a 5-speed. Ever since I got the truck it has always seemed kind of sluggish off the line. When I take off the power delivery is smooth but slow until I get above 2k on the tach. Is this normal? Does it just act this way because the powerband is a little higher? If this is normal I'm OK with it, I just want to make sure there is nothing wrong with it. It just seems that when I mash the go-pedal to the floor it loads up as slowly as if I was at half-throttle. Thanks in advance for any info!
Old Jul 7, 2007 | 08:00 AM
wreckit72's Avatar
wreckit72
Your EBPV may be sticking. You can just unplug it to find out. Most people just leave it unplugged.
Old Jul 7, 2007 | 01:53 PM
79F150EFI's Avatar
79F150EFI
Mine does the same. Powerband is higher on these than the diesels I and probably you are used to (big inline 6's). Above 2,000rpms my truck screams, lower than that I can hardly even build boost, but the truck still makes plenty of power to cruise in OD at 900rpms without lugging.
Old Jul 7, 2007 | 03:19 PM
glasseater's Avatar
glasseater
my truck has plenty of torque from about 1400 rpms all the way through the rpm range... it's slow till it gets to that magical 1400 rpm range but after that it rockets... idk it might be cause of my intake?? i know that normally a more open intake will cause a lower torque band
Old Jul 7, 2007 | 03:56 PM
powerstroked162's Avatar
powerstroked162
i know that normally a more open intake will cause a lower torque band....... I dont think thats very accurate.
Cowboy Steve
Old Jul 7, 2007 | 04:05 PM
wreckit72's Avatar
wreckit72
Glasseater, those 34's might have something to do with your truck being slow under 1400 rpm's.
Old Jul 7, 2007 | 05:14 PM
SrqScion's Avatar
SrqScion
Yeah, alot of how the truck takes off has to do with what gears you have too. I have 4.10s and it will throw you back pretty good when all 8 injectors are working, lol.
Old Jul 7, 2007 | 05:24 PM
wreckit72's Avatar
wreckit72
If you haven't already you may want to get a Tymer intake or do the 6637 kwik filter. It may need more air. I have the 4:10's also. I am not sure if these trucks are sluggish with the 3:55 gears.
Old Jul 7, 2007 | 05:34 PM
glasseater's Avatar
glasseater
i don't necessarily mean slow.. i just mean slowER haha it's still quick through all the rpms but it really comes alive over 1400 rpms
Old Jul 7, 2007 | 08:45 PM
outlaw219's Avatar
outlaw219
Thanks guys. A Tymar is next on my wish list.
Old Jul 7, 2007 | 08:54 PM
powerstroked162
You'll enjoy it my friend
Cowboy Steve
Old Jul 8, 2007 | 10:04 AM
RocknXJ's Avatar
RocknXJ
I think the 4.10 gears must make a pretty big difference. I have friends with chipped SD's (everything else stock) and 3.73's, and their trucks don't feel nearly as fast as my '96 with 4.10's. Mine will burn rubber with just a blip of the throttle and there's won't burn rubber just by hitting the throttle. Adding the IC didn't seem to hurt the throttle response at all. I'm sure the heavy torque converter helps, too. It pulls pretty good from rpm in the low teens but does gain as it goes over 2000.
I drive 6ohs quite a bit at work, and their throttle response is terrible. Once they get going it's good, but you hit the gas and then wait.
brian1080
Nov 11, 2012 01:01 PM
Gental Ben 2
Jul 11, 2010 04:55 PM
98greensi
2004 - 2008 F150
17
Nov 5, 2008 07:47 PM
boggerted
1983 - 2012 Ranger & B-Series
Aug 16, 2007 08:03 AM
psu927
17
Jan 1, 2006 07:46 PM
