General Automotive Discussion
Chevy issue
Old Jul 8, 2007 | 09:35 PM
Tom's Avatar
Tom
Well, that's something i'm unsure about....
As you can see in the picture I posted above, the gasket was leaking badly, and it looks like it was leaking down into the valley and getting in the oil...but I never could find any coolant in the oil! I checked many times, and the oil level never rose, and I never found any evidence of milky oil. However, after having the top side of the engine exposed all night long, I plan on changing my oil no more than a couple hours after I get it all back together...
Old Jul 9, 2007 | 11:05 PM
Tom's Avatar
Tom
Thumbs down
Well, the I got it together today, it took me about 5-6 hours. Once I got it together, I filled it up with antifreeze, started it up, and everything seemed good. So, I drove over to the parts store, rented a coolant pressure test kit to see if everything sealed right.
AAAAHHHH, STILL LEAKING!!!
I found the leak, it's dripping down the front of the passenger side of the block...but it doesn't look like it's coming from the intake manfold...
Here's the best picture I can get...
Does this look like the freeze plug is leaking? If so, how do I replace it? I'm gonna pull the a/c compressor and mounting bracket tomorrow to get a good look...what do you guys think?
Old Jul 10, 2007 | 12:54 AM
Bill W's Avatar
Bill W
YEA freeze plug You can Carfuly Poke a screw driver in it and try to pull it out. How many miles? where theres one there might be More,looks kinda rusty.You dont see that Much in AZ. I think there is some DYE you can add then with a speical light you can detect all, Not sure about the last part thou.
Old Jul 10, 2007 | 01:17 AM
wizzard351's Avatar
wizzard351
that looks like the center port witch is a egr/heat riser thingy.it isnt a water port.i doubt even if a try to scrape it clean youll get all of it.when i got an intake of i usualy fill that hole with bondo to keep the heat away from the carb
Old Jul 10, 2007 | 08:54 PM
jimdandy's Avatar
jimdandy
Put a punch on the solid part of the plug, usually the upper part, hammer it till it turns sideways in the hole, then pull it out with pliers.
To install, find a socket that fits into the new plug, cover the plug good with Permatex copper, put an extension in the socket and hammer it back in. jd
ElMoco
46
Nov 28, 2016 09:42 PM
comingback2ford
Jul 14, 2013 03:57 PM
superduty1967
Oct 1, 2012 09:11 PM
1979Mustang
Apr 30, 2012 03:44 PM
Fordworth
Aug 30, 2009 03:22 PM
